R32
Ronin 09
Others
Integra...just a generic one
Still all good for Sunday with these Troy?
PS I have RB74s now, and they feel pretty good... did some freeway 'testing' last night :P see how they go on Sunday. I tend to have a habit of cooking brakes :cooldance
  • Replies 409
Yeh no probs. Got some bits and pieces yesterday. I should have got my car back from wheel alignment yesterday, but wont be getting it now til Tuesday...so then ill use my car to get the lengths right:)
Id suggest next saturday to fit them....im in Brunswick.
Too easy :P
so will your beasty be ready for Sunday? (not taking the piss, BTW, a serious qn) :D
Ill be there, the level of success i enjoy depends on a few things.
The tune needs to be finished, and while its there parts that were left off the car need to go back on, and they need to fix a strange timing/engine miss.
Then i need to get my new brake pads, bleed the fluid...wrap my exhaust manifold in its jammies and change the oil.
Going to be a few late nights this week...how that fits in with work i have no idea...most likely ill get sacked:(
Any spots left guys?
There is someone from here who will have to pull out (Adzmax) so if you are interested maybe you could take his spot. It will be cheaper to do that anyways as we have past the "early bird" cheaper rates day.
Also guys - I know its not as helpfull as being there but at the Club meet on Tuesday night I will bring my PS2 along (so that we can watch Shiv's DVD from Phillip Island on the big screen mostly) but also to give any first timers to Sandown a quick run through on the simulator the layout of the track. After spending a lot of time there yesterday with first timers to this track I have remembered just how difficult it is to find the fast way around this track if you don't have someone to give you some advise.
Hey guys just a heads up...
Bodily unmodified vehicles built after 1973 dont need a secondary bonnet restraint. Checked this today with Jim from Maserati Club, it also says that in the fine print before the entry form...
Are you sure...it does say for forward raising bonnets ie 240Z etc. Id be very surprised if a rear hinged cars like R31/32/33/34s dont require them.
Just what I got told today yeah, coz technically they do already have a secondary, standard wire clasp and then hook...
Perhaps someone else could query it, so we can get a firm answer?
Just got some Motul RF600 and Comp 9 front pads. Sold out of DS3000s, the Comp 9s are a few runs further up the ladder then the RB74s but still well short of Hawk Blues, DS3000s etc. Be interesting to see how they go...Silver Arrows was always happy with them on his GTR:)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
