If there is such a product called spray on silicon i will be try this over the weekend.
Another theory im curious about is; If the silicon is effective in insulating the spark, couldnt you use a bigger gapping as you would have a very strong spark thus more power? The reason being is reducing you gap also reduces power/kw on the dyno.
  • Replies 148
Posted Images
I've actually had a few good tuners tell me that regapping your plugs 'down' to 0.7-0.7mm is actually a work around for bad spark (bad plugs or bad coils). They both said 12psi (stock turbo/ecu) can be obtained by a good set of coils/sparkplugs.
Silcone is a good insulator, but I don't know if it will stick to the particular type of plastic the coil packs are made of.
At the plastic welding place I went to, I asked what alternatives there are to araldite, and he said possibly fibre glass (just the resin, which is also an epoxy), but nothing will stick better than araldite.
Why are you pushing for other alternatives?
In regards to gap, theoretically, yes.... you can increase your gap now for a bigger spark.
well I am going to coat my plugs in a layer of silicon (roof and gutter so it wont react with anything), and see how thats works. that should stop the spark! Iam only pushing for silicon cause araldite doesn't perform well under heat, the glue begins to get soft and sticky again, and may run!
it shouldn't.
if you look at the back of the coil pack (the tallest part), it is sealed off with an epoxy - not much different to araldite. Well this is what I was told when I took them to get plastic welded. I told the dude that temps around the coil get quite hot, and he said it wont be an issue.
Tell is if the silicone sticks, and I was told not many thinks will stick to this type of thermoplastic besides araldite. So there may be a concern of the silicone peeling off after a few weeks or so.
Hi guys,
My R32 GTR was also missing at high revs with above stock boost... I changed my plugs to Iridiums and then the problem became more apparent. I check my coils and there were two that were cracked. I've coated the coils now in "Permatex Ultra Black HI-Temp RTV silicone gasket maker" and it's look like the missing is gone in all but the highest(1.3 bar) boost setting.
I'll let you know if I have any problems.
Cheers,
Brad
My missing has been completely fixed now on both 7 and 12psi. The only problem I have now (which is the same as before the missing started) is that on 12psi it feels flat in the higher rpm's.
  • 1 month later...
I have been having some recent problems with my rb25. It seems to be popping and back firing when acceleration between 4 and 7 rpm. I have changed coil packs, spark plugs, igniter box even the coil pack loom and still no luck.
I thought it could possibly be something to do with my fuelk system as it seem sto feel like fuel cut when it happens. If anyone has come across the same problem could they please e-mail me on, [email protected] as i have done nearly everything and ready to give up.
I have read the previous replys and and not sure where exactly you are putting the epoxy glue on the pack.
Thanks, James
Hi guys I have a full set of brand new splitfire coil packs for sale (cheap) for GTR, R32 or R33.
which give a heaps better performance and stops the 4000-5000 popping dead in it's tracks!
http://www.skylinesaustralia.com/forums/sh...ead.php?t=57340
    • Here's a boring history lesson on number plates People want illegal spacing to make their plate more readable, if mine was J2X BK, anyone who knows about the car would see that its spelling JZX. Years ago third party plate manufacturers could alter the text to make it look like something else, nowadays the computer software is locks that ability (well, ours does at work) Up until 2001 the first letter of a number plate represented the year of the vehicle, for example A would be 1983. (pre 1983, the format was backwards, so the year letter was on the end). Followed by 3 random numbers and 3 random letters. Things started to get complicated at the end of the 90s where T and V were 1999, W and X were 2000 and Y was early 2001. From 2001 they introduced a new 'layout' where the first two characters are letters, this represented where that vehicle was first registered in the country. The letters corrosponded to a region in the country. Some regions had a large number of codes, where as some only had a couple (despite being large in physical land size) Next are 2 numbers to indicate 2000s. So it went from: Y (March 1999 > Aug 2000) 51 (Sept 2001 > Feb 2002) 02 (March 2002 > Aug 2002) 52 (Sept 2002 > Feb 2003) etc etc When the 2010s got here, the numbers changed again, going up by tens 10 (March 2010 > Aug 2010) 60 (Sept 2010 > Feb 2011) When the 2020s arrived it went to 20 (March 2020 > Aug 2020) 70 (Sept 2020 > Feb 2021) etc As for personalised plates, you're not allowed a registration that makes the vehicle look newer. Take my 110 for example, its a 2004 car so I can have any available plate upto 04. I can't have a 54 because it was manufactured in August 2004. Which allows me to have a J plate, because its older (if that makes sense)
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
