  • Replies 148
Posted Images
Listen to what Rolls has to say
I jsut put some octane boost/fuel system cleaner through my car and my car revs straight out now, no stopping, popping, nothing
is the only thing that has changed since i taped up my coils.
taping fixed it for a week but then it went back to normal
i think i may definately have to get my computer reprogrammed to run on 98 octane fuel as i cant afford to be buying octane boost ever tank of fuel
Yeah my popping was due to an injector problem. I ended up getting coils that definately worked and I still get the popping.
Using your standard electrical tape is not a permanent fix b/c the tape shrinks with heat.
It must have been a fluke with the octane booster b/c the difference that stuff makes is negligable in my experience.
So how are the coil packs hanging out guys ?????? An update as to whether the araldite works would be nice.
Hey rickhead,
I've been using it for 10-11? months now... still runs PERFECTLY.
If you do it though, make sure you do it right and spend the time to put plenty on in the right spots...
Howdy 'yall.
Just thought I'd mention that I had the problem, checked my colis and found 4 out of 6 coils had cracks. I areldited them up and the misfire has gone.
It's been 2 weeks now.
Thanks to all who contributed.
Chris
Guys,
I went against the trend here and used Roof/Tile/Gutter silicon. Its rated to 150 degrees C and I covered the entire pack in a thick coat leaving ony the plug clear.
I also gapped my plugs to 0.8mm since they were at 1.1mm. Seems fine so far but early days yet.... Update in a few weeks.
PS: Be careful when you put the coil pack bracket back in (the metal strip that hold 3 packs) it goes in a certain way. It even says UP and Front or rear on it. I missed it and almost cracked my coil packs :) whoops..... just a heads up!
I had a look under my bonnet when the car was warm and in the very dark I can see arcing on I think all of them!! They are not meant to do this I think. I might be better going for splitfires then. I have a used car warranty so I may be able to get them under warranty...we'll see.
They appear to be about 570 for the set - not too bad!
I can't believe the car is running well untill you get to 7psi or so. Looking forward to smooth running at 9 or 10psi :)
You have to look very hard for the arcing. I'm just running it woithout the spark plug cover and because its series one I have just cable tied the module to the brake lines...
I have pics but have been unable to post them but i got rid of the Standard Coils and have replaced them with Bosch 716 MEC coils $250.00 for the coils and $50.00 for leads works with the standard series 1 ignitor if i can post the pics to someone to upload them PM with your email address and i will send them
they are quite big though as the camera is 6 meg
Rob
On the same subject has anyone seen or used the AEM setup advertised in HPI occasionly? It has a plug for the ignitor to connect to and then it used leads like an ordinary setup. It claims superior performance to OEM coilpacks.
Anyone know the cost or had any experience with it? I imagine from the sounds of it the Bosch is a similar setup?
If you can see any light around the coils they are leaking right? I can only see it when it is very dark and it is only quite faint. But it is definately lighting up on 3or 4 coil packs.
The mechanic couldnt find it today. Maybe it wasn't dark enough..
is it possible to post this article regarding the ARM setup. Seems interesting.
my car has not missed a beat since fitting the Bosch coils and the bonus is now changing plugs takes next to no time I do not even have to remove the crossover pipe.
the good thing about the bosch is i can at a later date fit a CDI to the coils
I only have faint light from the coils at idle. Can only be seen when very dark. Is this what is causing a misfire do you think? The mechanic reckons it could be CAS or module. He thinks you would see more arcing if it were a problem. He ran it on he dyno and could not see any big arcs. although the car was not that warm I don't think
Does it have to be a big arc to cause a misfire??
Im pretty sure any arc at all will be taking current away from the spark which will at least weaken the spark, possibly causing a misfire.
If you can see where the spark is coming from, cover that area in glue/tape etc until it stops arcing and see if this fixes it.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
