I've got a 1998 RS260 so the RB26DETT from a R33 GTR.
Put it on the dyno last weekend and it only pulled 110kws with 4psi boost?
I've just brought a power fc from japan and looking to get a Turbosmart E boost street.
What could be to problem before I put the parts on and tuned.
I would think it should have more power than that standard.
Thanks
Nick
Thanks
Nick
I dont know much but Id say the 4psi of boost will be part of the problem, for sure. What were the AFRs? Could be running very rich too.
Well thats what i think. I cant understand why its running 4psi. It should be waste gate pressure.
I'm hoping to be over 200kwsatw once tuned and 10-14 psi on the standard turbos.
Anyone know what the R33 gtr turbos will run?
Nick
I think 10psi is standard. 14psi is about the max you want to run safely. I'm running 13psi on my 260RS and have 200kwatw. Perhaps you have a blocked cat or a boost leak or something like that. 4psi is less than actuator pressure I think.
Impul ecu run just happened, much better than last time.. 173.5kw on the same dyno (we made a whopping 126 last time), and a stack more torque too! :D
A bit rich but more than liveable Dunc, I wonder if it is just running out of injector at max revs... :dry:
Knew there was something else I was meant to ask about :D next time.
What'd reckon my target AFR's should be? I'd assume at this point the only way to get it better leaner (aside from waiting for the Impul to self tune) is either emanage or an AFC?
Knew there was something else I was meant to ask about :dry: next time.
Yep, dont bother with the AFC, Emanage is very good at what it does and will allow multiple maps (e85 hint hint) and self tuning with a wideband.
You should be aiming for flat 12afr at full throttle, right through the revs. You are safer than that so theres no issue (other than fuel consumption) but if you notice it leans back out to 12 at the end, im just not sure what caused it. The injectors should be good for over 220. Perhaps its the pump but I would say its just a weird tune. Looks like you picked up a good one there. :D
Nice result Dunc.
Stock boost on your car is 12psi.. If you did the bypass on the boost solenoid you can have unlimited boost.
I think Craig has seen 24psi using my Impul ECU at the moment as there is no boost cut on this ECU.
Cheers
Andy
Hrm weird, I did do the bypass. Manifold pressure graph looks like it maxed out at 15psi though :dry: last time I maxed out at less than 10 pounds though.
Edited by Dunc
May have something to do with the exhaust? I know that Craig has 3" from the turbo back, so less restriction.
Can't remember what you have Dunc (is it just the group buy dump and stock exhaust?)
ah good point. At the moment Ive got a stock dump, with a 2nd cat in the pipes, and a nismo adjustable exhaust muffler (which was set to sport for the run). Might need to give that new group buy dump some consideration.
Edited by Dunc
Even if you don't touch the rest of your exhaust, change the dump pipe.
Certainly the biggest power boost when you do this. There is a massive cat in the middle of the stock dump that is soo restrictive.
On my car with the stock turbo I have seen 20psi when I did the bypass. Not for long as I don't thing the ceramic turbine will be happy for long even with a ball bearing core.
Cat in the stock dump is too restrictive?
Oh, you must be referring to this then :)
Yes Dunc. Change your sump pipe ASAP!
Either get in on the group buy unit or preferrably, talk to Scotty about one of his dump/front pipe units :happy:
+ 1 million! :happy:
I can vouch for the difference it makes even with a standard exhaust. Spools up faster, accelerates harder, more responsive, nicer engine note, slightly better fuel economy, need any more reasons? :)
  • Splitfire Coil Packs
  • FMIC 11psi
  • SAFC II
  • 2.5" Gutted Cat
  • Same as above plus
  • 3" Front Dump pipe
  • SITC
  • 3, 1/4" Cat back
  • Reinforced intake pipe
  • Boxed pod with CAI
  • Grounding kit
  • 3" Highflow cat
  • MV Auto's stage 2 shift kit
  • R32 GTR 5 Speed, HD fly wheel and clutch
  • Denso Hi-flow fuel pump (stocker wasnt keeping up while being tuned today)
  • 12psi allthough it has to be pulled out towards the top so it doesnt hit boost cut :-(
Not sure where to from here.... Im at the end of the road AFM and turbo, tapping boost cut every so often.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
