I've got a 1998 RS260 so the RB26DETT from a R33 GTR.
Put it on the dyno last weekend and it only pulled 110kws with 4psi boost?
I've just brought a power fc from japan and looking to get a Turbosmart E boost street.
What could be to problem before I put the parts on and tuned.
I would think it should have more power than that standard.
Thanks
Nick
Thanks
Nick
I dont know much but Id say the 4psi of boost will be part of the problem, for sure. What were the AFRs? Could be running very rich too.
Well thats what i think. I cant understand why its running 4psi. It should be waste gate pressure.
I'm hoping to be over 200kwsatw once tuned and 10-14 psi on the standard turbos.
Anyone know what the R33 gtr turbos will run?
Nick
I think 10psi is standard. 14psi is about the max you want to run safely. I'm running 13psi on my 260RS and have 200kwatw. Perhaps you have a blocked cat or a boost leak or something like that. 4psi is less than actuator pressure I think.
Impul ecu run just happened, much better than last time.. 173.5kw on the same dyno (we made a whopping 126 last time), and a stack more torque too! :D
A bit rich but more than liveable Dunc, I wonder if it is just running out of injector at max revs... :dry:
Knew there was something else I was meant to ask about :D next time.
What'd reckon my target AFR's should be? I'd assume at this point the only way to get it better leaner (aside from waiting for the Impul to self tune) is either emanage or an AFC?
Knew there was something else I was meant to ask about :dry: next time.
Yep, dont bother with the AFC, Emanage is very good at what it does and will allow multiple maps (e85 hint hint) and self tuning with a wideband.
You should be aiming for flat 12afr at full throttle, right through the revs. You are safer than that so theres no issue (other than fuel consumption) but if you notice it leans back out to 12 at the end, im just not sure what caused it. The injectors should be good for over 220. Perhaps its the pump but I would say its just a weird tune. Looks like you picked up a good one there. :D
Nice result Dunc.
Stock boost on your car is 12psi.. If you did the bypass on the boost solenoid you can have unlimited boost.
I think Craig has seen 24psi using my Impul ECU at the moment as there is no boost cut on this ECU.
Cheers
Andy
Hrm weird, I did do the bypass. Manifold pressure graph looks like it maxed out at 15psi though :dry: last time I maxed out at less than 10 pounds though.
Edited by Dunc
May have something to do with the exhaust? I know that Craig has 3" from the turbo back, so less restriction.
Can't remember what you have Dunc (is it just the group buy dump and stock exhaust?)
ah good point. At the moment Ive got a stock dump, with a 2nd cat in the pipes, and a nismo adjustable exhaust muffler (which was set to sport for the run). Might need to give that new group buy dump some consideration.
Edited by Dunc
Even if you don't touch the rest of your exhaust, change the dump pipe.
Certainly the biggest power boost when you do this. There is a massive cat in the middle of the stock dump that is soo restrictive.
On my car with the stock turbo I have seen 20psi when I did the bypass. Not for long as I don't thing the ceramic turbine will be happy for long even with a ball bearing core.
Cat in the stock dump is too restrictive?
Oh, you must be referring to this then :)
Yes Dunc. Change your sump pipe ASAP!
Either get in on the group buy unit or preferrably, talk to Scotty about one of his dump/front pipe units :happy:
+ 1 million! :happy:
I can vouch for the difference it makes even with a standard exhaust. Spools up faster, accelerates harder, more responsive, nicer engine note, slightly better fuel economy, need any more reasons? :)
  • Splitfire Coil Packs
  • FMIC 11psi
  • SAFC II
  • 2.5" Gutted Cat
  • Same as above plus
  • 3" Front Dump pipe
  • SITC
  • 3, 1/4" Cat back
  • Reinforced intake pipe
  • Boxed pod with CAI
  • Grounding kit
  • 3" Highflow cat
  • MV Auto's stage 2 shift kit
  • R32 GTR 5 Speed, HD fly wheel and clutch
  • Denso Hi-flow fuel pump (stocker wasnt keeping up while being tuned today)
  • 12psi allthough it has to be pulled out towards the top so it doesnt hit boost cut :-(
Not sure where to from here.... Im at the end of the road AFM and turbo, tapping boost cut every so often.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
