had the stagea on the dyno with the 3076 .82 on.
everythn standard besides
exhaust 3 inch
fmic
pod
nistune
made a nice 240rwkw on 11psi.
cant wait for injectors pump and afm. im planing to run 17 to 18 psi and should make the 300 to 320kw mark. il let yas now how i go once i finish the mods.
How lean is it?
I am only getting a bit more on 15psi, 245-250rwkw
How lean is it?
i lookt at the afr and they seem fairly stable. i told the guy i got tuning it that its gonna take a beating so i want it safe. so hes done what he can with the standard injectors. il see if i can get a couple of print outs and post em up for ya. injectors are running 90% duty. i was shockt it made over 200kw with em.
  • 4 months later...
its pork hunt drifting here im on mates user name cause i cant remeber my pass.
i had rbpower on the dyno again after putting new coil packs in and upping boost from 12 to 14 lbs.
the cars now making 262rwkw with
garret 3076
3 inch custom zorst
pod
fmic
nistune
just put a z32 afm on this arvo and gona lift boost to 16psi if standard injectors let me. they only seem to be running 70 to 80% duty at moment. il update results if i get another tune on sat.
Had my car dynoed at Edge Motorworks by Cihan today...well its the 2nd time. Last week I had my LPG and Petrol tune. Today was E85/Flex fuel tune.
Mods - Note - "Custom" = Scotty's fabrication :worship:
Custom suction pipe
Custom dump/front pipe to Fujitsubo Legalis
Stage 1 hi flow @ 17(?) psi
HDI Intercooler
Blitz SUS Power air filter
Turbosmart boost controller
Greddy Emanage Ultimate
trans cooler
RVO Auto stage 2 shift kit (valve body upgrade/line pressure increased)
610 Deka injectors
Walbro GSS342
JTG Liquid Gas Injection system
Results:
98RON: 247awkw, ~800NM
LPG: 250awkw, ~850 NM
E85: 270 awkw, ~950NM
didn't get dyno sheets as printer not working!!
this is a "screenshot" from last week:
Pretty happy with the results...next step is looking at an EBC and modified actuator to hold boost
Very nice mate, and I am back to the stock turbo. >_<
Glad you like my old setup. How does it feel? :thumbsup:
That pic is terrible, I will see if I can get a print/photo of your 270kw run later today.
Its good!!! Its nuts when it hits 3k+ rpm
Yeah, see if u can get something. He would've saved it right? I dunno...Cihan was in a real hurry to leave...had issues getting my car OFF the dyno LOL...and those straps...I think you better make some miracles with those bits ur welding onto his dyno!
Custom suction pipe
HDI Intercooler
trans cooler
610 Deka injectors
Walbro GSS342
Results:
NICE!!!!......stick up the e85 run when you get it.....what boost? you'll like the modified actuator.....bit of a gain for yah....have you changed you plugs yet?
Edited by Jetwreck
Looking at the dyno graph, does anyone know what causes tha power dip at 3500rpm??
I have a stock M35 and can feel a very noticeable loss in power at 3500rpm, which is also in the dyno result above?
Also, what is the actuator mod mentioned above?
At a rough guess, I'd say it was the Torque Converter locking up in the Auto gearbox.
I think I've seen it mentioned in other dyno graphs by people with Autos, but I'm happy to be wrong if someone has a better explanation.
yeh what PN-Mad said.
The modified actuator is done but putting a bigger spring on the outside....sort of works like a preload.
Works good too, brings it all on heaps earlier, just like the grub screw in the BOV. :thumbsup:
I just got back from tuning after fitting the stock turbo, it was only a temporary tune as Garrett is out of GTX turbo's at the moment. Running ethanol and pushing 1.2 bar the stocker made 225awkw and 850nm. I might just stick with this one for a while... :cheers:
This is a good representation of what a stock turbo (17psi) and a stage 2 (20psi) can do on ethanol, overlaid on the same graph. Cihan was very impressed with the stockers capabilities.
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
