Spotted two yesterday (NYE), both on exactly the same area of the same stretch of road, but around 10mins apart.
The first was a silver s1 (rego BAY-76Z, I think), with some silver pinstriping on the tail lights in a rectangular pattern. The second was the white s2 that I've seen quite a bit in my area over the past year or so (rego COP-003). Both spottings were on Seven Hills Rd (aka Prospect Highway) right near the intersection of Station Road, and both cars were heading away from Abbott Road and the M2...
Hey i saw the white Series 2 heading towards Seven Hills Shops on NYE too. It good to see a few more popping up around the area.
Has anyone seen mine S2 rego (BDS-22T)????
spotted silver ser1 with body kit on hervey bay esplinade looked nice, also I can't believe that after 4+ years of ownership I still have not been spotted :( I have waved to many fellow stagea owners but no spotted post :D anyway nice car who ever you were.
Edited by rb30dett
hey was it parked or driving ?
didnt see you tho unless you were one of the many drunks i drove past haha
Also today out side 'Rays Outdoors' in dandy plates were non other then ...... STAGEA
was gonna park in front of it but would of left you no room. looks very nice man
you were driving i didnt get a great look at yours but enough to get the plates,i dont have the STAGEA plates but ive seen him once or twice my plates are WGNC34
spotted a white Stagea on heatherton road about an hour ago with custom no plates.. forgot them though >.< thought it was you RBPOWA but wasnt lol
that one definitely could have been me probably dropping off the ball and chain lol
pretty sure i spotted simons old rig on canterbury rd/springy rd intersection.
had different wheels on it, but dead certain it was his. did he sell it?
white s2 in ftg, the road where maccas is. seen it a few times, was unfortunately blowing a bit of smoke :D
and a white s1 or s2 on the westgate fwy saturday or sunday...
starting to become common now.
ahhh damn you, i wanted those plates !
there is a guy on here just by pure luck his plates are standard ones WGN-342 series 2 so it makes sense
westgate freeway Saturday think it might of been between 5-7pm if so that was me.
FTG ? fountain gate ? im around there alot , gf lives near by, but no smoke from me.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
