Spotted yesterday: Grey s1(?) leaving Carrara markets at about 1pm: tried to catch up in traffic for about 6 km, and got cut off at Ashmore Rd lights by an idiot in a Rav4 (thanks, whoever you are: idiot!), so never got to wave/toot etc...
ive seen quite a few lately... a silver m35 parked on the street at bondi beach... a black m35 on friday afternoon on that road that fitness first and subway is on in penrith... and the other day me and the missus just sat down at a restaurant for a feed in penrith, there was a group of girls leaving right next to us and one of them came over and told me that she owned a stagea aswell... we had a good ole chat for a few minutes she told me how happy she was with the car and how they've got everything... was good to bump into another stagea owner in a random places...
Edited by Space Goat
were the girls hot? and did you take pics of them?
that stagea might have been mine at bondi beach. i was there friday night..........
no pics sorry boys... them 35s are getting pretty popular
Spotted Duncan's car this afternoon in Castle Hill.
Yeah also spotted Duncan's white one at hills motorsport
right....so tell me it was on the hoist and they were just finishing up dropping the new motor in....
and at yellow one near ISIS, plates were "DL 8896" i think?
that would ms wolv (plates are close enough and she works over that way)
Edited by wolverine
spotted rb26stagea at 4wd performance today
FINALLY!!! I got spotted legitimately! I have waited so long! I spend a fair amount of time there: Ben is a good mech... I was playing musical cars today, where were you?
I was cruising around today, and believe I spotted Chook on Nerang-Southport Rd: waved, but was with GreenGhost in the work truck, so not sure if he knew it was him I was waving at.
I was in there talking to him about fitting my intercooler
he fitted one to my mates gto and did a good job so i thaught i'd give him a go
got a shock when i saw you parked there
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
