Spotted a white s1 this afternoon on the M2 motorway in Winston Hills, it was heading away from where the M7 stops and becomes the M2 (heading North).
Was it you, Duncan, by chance?
Spotted CL11QE yesterday in his garage, and helped get it running again!
That counts as a fair spotting, before anyone asks, because I AM THE MODERATOR AND I SAY SO!!! :)
Hehehehehe
i want you front lip! i also love your car
Its funny you should say that. I hit a fox the other night and it took a chunk outta my front lip. Spewin!
Might claim it under my insurance, not sure yet though.
I rarely post on these forums, but I came out from the shops today and there was a yellow S2 parked next to me! Armadale Shopping Centre (Perth). Took some pics. ;)
I have seen this one around a few times.
Edited by revolt
Good work Trent good to see you OUT & ABOUT car looked sweet hope to see you on cruise when we set date & map cheer`s chuckie .
hope you took a chunk out of its head !!
so what the name of your front lip ? is it a dolphin or somthing ?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
