Spotted a white s1 this afternoon on the M2 motorway in Winston Hills, it was heading away from where the M7 stops and becomes the M2 (heading North).
Was it you, Duncan, by chance?
Spotted CL11QE yesterday in his garage, and helped get it running again!
That counts as a fair spotting, before anyone asks, because I AM THE MODERATOR AND I SAY SO!!! :)
Hehehehehe
i want you front lip! i also love your car
Its funny you should say that. I hit a fox the other night and it took a chunk outta my front lip. Spewin!
Might claim it under my insurance, not sure yet though.
I rarely post on these forums, but I came out from the shops today and there was a yellow S2 parked next to me! Armadale Shopping Centre (Perth). Took some pics. ;)
I have seen this one around a few times.
Edited by revolt
Good work Trent good to see you OUT & ABOUT car looked sweet hope to see you on cruise when we set date & map cheer`s chuckie .
hope you took a chunk out of its head !!
so what the name of your front lip ? is it a dolphin or somthing ?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
