Saw a green S1/S2 stagea in the car park at Gravox factory in Seven Hills on Tuesday. I was going to the city by train and woke up when passing the complex. A pleasant surprise :) Are they a forum member by chance???
Possibly Nick (Goldzilla), he has a green machine and lives very close to the Seven Hills area.
I'm sure he will pipe up and let you know if it was him.
Saw a green S1/S2 stagea in the car park at Gravox factory in Seven Hills on Tuesday. I was going to the city by train and woke up when passing the complex. A pleasant surprise :yes: Are they a forum member by chance???
Hmm, I live VERY close by to that, but I don't remember what I did on Tuesday - what time was this?
Good day for spotting today, drove from Blacktown to Gosford and spotted 2 AR-X's about 30 minutes apart.
Both were even the same colour! (champagne I think it's called).
Spotted the first on Pennant Hills Road, he was turning off onto a side street, exchanged flashes of lights and a quick hoot.
Next was on the F3, near Berowra King M35 passed me in the fast lane and we exhanged hoots.
So there you go, a good day for spotting!
Blue M35 Nismo kitted, on the westgate freeway. had SA plates, awesome looking ride, you might of noticed my GF taking photo's. i was in the blue pulsar SSS.
also saw you parked at the Little River BP
this was Saturday around miday i think
Sounds like it couldve been me, I drove a section of the westgate freeway on saturday on my way back from the snow fields (Stayed in Melbourne friday night, then did the great ocean rd etc)
i did the GOR also :D to bad it was wet, much better on monday going home ?
i did the GOR also :/ to bad it was wet, much better on monday going home ?
Ah nice. We stayed on Lorne on Saturday, and then drove the scenic section of the GOR Sunday - was a stunning day for it, albeit windy. Monday was a nice day for driving also, an excellent trip over all :D
Spotted Phoenix88's yellow R34'd C34 at Pitlane Automotive.
Didn't have time to look under the bonnet, have you got the pod boxed/shielded yet?
Nah havent got that done yet. Im having electrical issues just trying to get them cleared up.
Seem to spot a black c34 on seaford rd at 7.30 most mornings any one on here?
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
