spotted a silver RS4 pulled over by cops at Christies beach this morning around 9.30ish, hope you didnt get done. then spotted another silver RS4 on Lonsdale highway, gave me a wave and did wave back dunno if they saw or not. anyone off of here ?? I was in the mrs white S2 RS4
Saw a white RS4 (Scotty), black ARX (Aaron), and burgundy ARX (KV2) on Saturday morning...
Can't wait till I pick up the are tomorrow nite...new exhaust...yuuuuummmmmmmm
My place is beginning to look like an import yard. :)
Exhaust is nearly finished mate, looks good too, just need the flange. How long before we find out what it flows? :whistling:
Hmm I know I haven't got it high flowed, but once I get the intercooler on, I think I'll take it to Cihan and have Emanage installed and tuned. if I got 200awkw I'll be happy...for a while :P
realllllllllly tempted to go ethanol though..............>_<
the turbos gonna say bye bye soon. might as well just do it. oh n if your looking for a front bar, theres an impul one on IM for $230 + shipping.
have a look.
Oh and the exhaust looks really good. i think i want one...:ninja:
Edited by AaronNM35
have a look.
I think Scotty said he wanted to see what a stock turbo will do on E85...maybe I should show him :P
Hmm that impul bar does look nice...but its gonna cost $500 just to get here, then another 2-300 to paint and fit. Whereas I can get an aero selection bar in a few weeks time for $400 already painted and ready to fit.
It does look cool though...:laugh:
oh in that case, look for the fog lights.. if you pick up your car and it doesnt have an exhaust.. Im just testing it for you..:happy:
LOL...r u running a custom as well? Thought u don't like quiet exhaust :P
Hmm stuff the foglights. The car's already got built in ones...no need for another. I know they look nicer but its not worth another $700...
Spotted a white S2 with Epic Body Kit of some description on King Street this morning. Had SA plates.
Hey man,
Do you work in Melbourne CBD? i think ive seen your car driving around towards the evening.
Spotted A white RS FOUR this morning on Hampton Street Hampton...
Bloke and a girl got into as they were leaving the Guitar shop I think?? Had nice white wheels too... top looking car if your on here!!
I was in the ute...
Saw a white S2 on Kings Road about 2:15 gave him the flash
Dont seem to be many 34s round my area but ive seen a Silver 35 a few times on the same road that doesnt seem to want to acknowledge im there :sleep:
Hey man,
Possibly, I do live and work in the CBD. I walk to work however so the car only comes out after hours.
If you see me out and about be sure to jump on the Horn.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
