Spotted a white RS M35 on Wellington Rd, near Rowville yesterday... looked like Prince Skyline's car perhaps?
Flashed the highbeams and gave a wave as it came towards me (I was in the white Prado with trailer)
That would have been me if it was around 11:15/11:30 - On my way home from daughter's soccer in Narre Warren - always take Belgrave-Hallam Road then Wellington Road.
Didn't see you though - not that i would have blinked an eye. Often get flashed along Wellington Road for speed cameras...........
Spotted a blue NM35 series 1 around 5:30pm between Medlow Bath and Blackheath going east on the GWH. I thought I was looking in the mirror...same as mine. Didn't have my glasses on so only saw it as it was going past. Sorta waved but the 'A' pillar was in the way for the other party to see. So now I'm waving :action-smiley-069:
Black C34 at Tyres and More Prospect yesterday morning as I walked to work.
Black C34 (maybe the same one?) on South Road this morning.
Black C34 on south road may have been me, did you see the car from the front or the back?
Pale green S1 at Nerang.I Parked nose to nose. Talked to the owner who does not post much. Stag was Nina's who lived here on Tamborine. It went thru NizPro with a respray.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
