That would be me. I can only think of one place i park curbside in Ringwood though....haven't seen your car though!!
I'm in the third house from the top of the hill on the same side you are on. Feel free to pop over if you have a minute. Quite keen to check out the interior of a M35..
spotted a yellow S2 with yellow decal (business details on boot side windows) driving towards city on main north rd around Pooraka (how ever u spell it) nd then a silver S2 up near smithfield also driving back towards the city. both around 5.30-6 tonight
Very clean white S2 at the end of Greensborough Road waiting to turn right into Lower Plenty Road.
I was on the red R1 which did a little burnout then a little wheelie.
looking good in the Cube mate, I want one! if only for the fuel bill.
haha that is the good side.
the bad side is how hard it is to replace a broken side window :domokun:
BTW......I love the stag in this sort of weather, it is outrageously fun :D
White C34 this morning m5 South side =- just after m5 tunnels
That would have been me if it was just after 7ish this morning,
I also spotted a white c34 parked in westfield liverpool this morning around 730
Also Spotted yesterday at roughly 2:00 - 2:30pm heading down start of Marion road, Darlington. Blue C34, Possibly Zeke?? :action-smiley-069:
Sounds like it was me floating between jobs on sunday!! Hahaha WTF were where you?..I must of missed ya..where u in the Stag or am I just blind haha!!! >_<
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
