hmmm.....might be trimming mine a little then....looks lower than the standard one in this pic. I guess I'll have to wait for the trail fit but I do want it to be at least 85mm to 100mm off the ground.
the x'members 105mm of the ground already bottomed that out a few times and scrubbed the exhaust on a few speed humps and rear bar on a driveway, doesnt look as low as it is :( wish i could tuck rim and still be 100mm of the deck!!! i'll have to swap the 20's for 22's ROFL
spotted a black M35 with a aero front bar no foggies at Hawkesbury UNI today.
U mean 105 from the bottom of front var to the ground , or lowest point of car to ground?
the x'member is the lowest part of the car at 105mm, front bar is 150mm....... thats lowered 40mm allround but being the AXIS it runs the smaller radius tyres also.
here are a couple of pics of some sexy stags at AJD!!
<a href="http://s1209.photobucket.com/albums/cc395/matgersch/?action=view&current=DSC_0342.jpg" target="_blank"><img src="http://i1209.photobucket.com/albums/cc395/matgersch/DSC_0342.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1209.photobucket.com/albums/cc395/matgersch/?action=view&current=DSC_0329.jpg" target="_blank"><img src="http://i1209.photobucket.com/albums/cc395/matgersch/DSC_0329.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1209.photobucket.com/albums/cc395/matgersch/?action=view&current=DSC_0346.jpg" target="_blank"><img src="http://i1209.photobucket.com/albums/cc395/matgersch/DSC_0346.jpg" border="0" alt="Photobucket"></a>
seriously love that m35 on its guts >_<>_< sooo effing sexy
Fix ur mess please ;)
Seen a white m35 near mawson lakes , while I was on my scooter to wrk this morning , looked clean as ,
If you are showing images from Photobucket, you need to copy in the "IMG Code" not the HTML code.
thanks and sorry guys for that crap...havent used photobucket much as you can tell here are the proper links
hope this works
Spotted in my home state, a rare occurence! :thumbsup:
Spotted a silver AR-X on Hampstead Road with DC sticker on the back - Jidge? Partner was driving and had no interest in returning my wave! :whistling:
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
