hmmm.....might be trimming mine a little then....looks lower than the standard one in this pic. I guess I'll have to wait for the trail fit but I do want it to be at least 85mm to 100mm off the ground.
the x'members 105mm of the ground already bottomed that out a few times and scrubbed the exhaust on a few speed humps and rear bar on a driveway, doesnt look as low as it is :( wish i could tuck rim and still be 100mm of the deck!!! i'll have to swap the 20's for 22's ROFL
spotted a black M35 with a aero front bar no foggies at Hawkesbury UNI today.
U mean 105 from the bottom of front var to the ground , or lowest point of car to ground?
the x'member is the lowest part of the car at 105mm, front bar is 150mm....... thats lowered 40mm allround but being the AXIS it runs the smaller radius tyres also.
here are a couple of pics of some sexy stags at AJD!!
<a href="http://s1209.photobucket.com/albums/cc395/matgersch/?action=view&current=DSC_0342.jpg" target="_blank"><img src="http://i1209.photobucket.com/albums/cc395/matgersch/DSC_0342.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1209.photobucket.com/albums/cc395/matgersch/?action=view&current=DSC_0329.jpg" target="_blank"><img src="http://i1209.photobucket.com/albums/cc395/matgersch/DSC_0329.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1209.photobucket.com/albums/cc395/matgersch/?action=view&current=DSC_0346.jpg" target="_blank"><img src="http://i1209.photobucket.com/albums/cc395/matgersch/DSC_0346.jpg" border="0" alt="Photobucket"></a>
seriously love that m35 on its guts >_<>_< sooo effing sexy
Fix ur mess please ;)
Seen a white m35 near mawson lakes , while I was on my scooter to wrk this morning , looked clean as ,
If you are showing images from Photobucket, you need to copy in the "IMG Code" not the HTML code.
thanks and sorry guys for that crap...havent used photobucket much as you can tell here are the proper links
hope this works
Spotted in my home state, a rare occurence! :thumbsup:
Spotted a silver AR-X on Hampstead Road with DC sticker on the back - Jidge? Partner was driving and had no interest in returning my wave! :whistling:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
