Spotted Silver PNM35 while stuck in accident traffic on the M4 tonight.
Stock standard; blank canvas!
Also saw yellow C34 leaving the freeway while I was stuck in the traffic.
VIC traffic is way worse imo!
Ooo! New PM35 !
At least you had fans in traffic this time!
Btw, spotted the bluebird tonight, would it hurt just to wash it once a year?whistling.gif
Lol Alex, it looked exactly like yours did; Pre- Mods.
Spotted about 20 min ago: white M35 with black wheels and lip kit, being driven by a lady from Un iversity drive, along Cottesloe Drive in Robina. I stayed alongside admiring it for a short while: very neat looking car: I was in the Black BMW 5 series.action-smiley-069.gif
spotted a white C34 S2 parked on North Steyne @ manly just before 1pm
and also spotted (i forget his name) M35 - plates "SBxxBS" on Raglan St @ Manly also, gave him a thumbs up as i passed him in my work van :action-smiley-069:
haha, finally! spotted, after 2 years.
yeah thats my piglet, spotted you around a couple of times too! :D
Nice, glad someone finally spotted you, technically my first spot too. do you live around the area?
yours looked like a nice Stag, what's done to it?
Thats Spoolin12- Chris
Also known to stick his number plate on Lamborghinis!
Oh, and better keep on topic- the C34 Mailcall courier Stagea went past my place today! Still wonder if he is on here!
Edited by PN-Mad
Spotted Duncan on his way out of the City on the free way at Naremburn, didn't see me because he was to busy giving it the boot. whistling.gif
haha I don't boot it until I get out of Lane Cove Tunnel....you must have seen me cruising :banana:
spotted Andy yesterday afternoon in another sort of wagon. skoda octavia RS. i think it was an oil burner...........
Correct.... Oil burning Octavia RS with a little bit of tweeking.. :)
Back in my new Work Van now.. Oil burning again .. Transporter 4motion crew van with twin turbo... :)
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
