Spotted Theo's AXIS on the hoist at the Penriff choice A-one Stagea bro happy times workshop last night.
I hope he didn't put the suction pipe on because he will be pulling it back off for the actuator!!!!
nope its getting ceramic coated first :D
spotted you today Dale at 4pm on York Rd :P i was in the work BRICK lol
Lol, with mine; you can actually get the actuator out without removing it. ;)
Sneaky! Didn't even know; hope I wan't picking my nose... :woot:
Base coat is going on tonight, along with some parts for the Makinnen.
Turbo is off, exhaust housing is getting coated, new Meek performance dump, and X-force full system going on.
Full hard piping kit, and a Walbro going in tomorrow. In a month or so it's getting a Quaife front LSD, and going for a power fc tune.
power FC?
hmm interesting!
Possibly should clarify; the TME that I was referring to, sadly doesn't belong to me. It's a car in my mates workshop that is getting some love.
I wish it did; but fitting up a bunch of sexy bits to someone else's car is going to have to do for now.
Wasn't finished in time for me to see it run today unfortunately. It's going to be a hell of a thing though.
Spotted again a black C34 S2 Stagea with black mags on Yass Rd Queanbeyan NSW yesterday (15 Aug) at about 0830. SA plates - must be more than just visiting as I saw it in the same spot a few weeks ago.
saw the yellow rs4s aswell, passed on reservior rd, i gave a wave and revieved one back, i was in my silver c34 s2.
cheers.
Wow i got seen alot this trip. Ur S2 looks sweet. I wish mine wasnt so dirty. Also spotted the 2 white S2's, a white m35, a gold m35 and a silver m35. All in and around WTAC.
I think u had parked near mine on the Saturday at the start of the drifts till I left. Little higher up the hill nd a row or two closer to the final turn. Mine had all the stickers nf was 2nd in from the track
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
