What are the chances of two Lightning Yellow C34 S2 RS FOUR S's cresting the top of a sharp steep hill from opposite directions?
Well it happened this morning...WOOHOO!!!!!
Spotted a lightning yellow S2 C34 this morning on Gilbert Rd, Castle Hill this morning at 9:20 this morning. Flashes & waves all round!!!
That could be wolverine's wife, Gav. They live in that area and my sister used to see that car a lot when she was working nearby quite a few years ago.
That makes sense Nick, as I know Wolverine has an S aswell. I've seen it on Knox Rd, Woodcroft a while back too.....
Spotted a green S1 N/A basemodel (giggles) on Racecourse Rd, Hamilton while I was in Brisvegas last week. Took afew shots with my phone, but it was too dark. No rear wing, no privacy glass, hubcaps........
I thought I had the only N/A S1. It was a private import. The badge on the tailgate should read "25G". Mine is green but has a white bonnet and silver guards and is very beat up atm It has really dark glass and 17".. I don't drive it off the mountain but prefer the turbo S1 when going out.
Edited by 66yostagea
White M35 (lowered) heading south on Pacific Highway between Byron Bay & Ballina about 9:30 this morning. Was 'making time' like he was trying to get home from Easter holidays. You on here?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
