Spotted very slick C34 waiting to pull out onto GWH at Springwood yesterday; gave a flash, got a wave back.
Nice ride mate.;-)
That was the son,s car. Now you have seen the family's full collection :banana:
Was being stalked by #@Old Fella in Emu Plains today; apologies for having to look at the back of my Brown Stagea today.
Yours was looking immaculate as usual...
Must stop for a chat when I next see you; unfortunately was on my way to a funeral today.
This afternoon, I spotted that white S2 C34 that's regularly parked on/near Powers Road in Seven Hills. Looks like a trailer was attached to it, or it was very closely parked to the tow hitch on it.
That's generally where you are going in a hearse
Son and myself (C34 and M35) turned up at the daughters house and neighbour she was talking with said "Here are the two White Lady funeral cars arriving"
  • Like 2
Spotted Josh aka "Brick" @ my work tonight swapping exhausts
Really?
I actually had some respect for him, as I'd assumed he did it in the apartment parking space.
You've made things too easy for him Dave.
  • Like 2
Silver NM35 spotted lurking around garage sales in Wentworth Falls this morning.
Yes, I spotted it too? at the Old Bathurst Rd roundabout near the Blackburn Hotel in Katoomba yesterday. I waved to the driver as I turned off the roundabout and received a nod in reply.
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
