Spotted very slick C34 waiting to pull out onto GWH at Springwood yesterday; gave a flash, got a wave back.
Nice ride mate.;-)
That was the son,s car. Now you have seen the family's full collection :banana:
Was being stalked by #@Old Fella in Emu Plains today; apologies for having to look at the back of my Brown Stagea today.
Yours was looking immaculate as usual...
Must stop for a chat when I next see you; unfortunately was on my way to a funeral today.
This afternoon, I spotted that white S2 C34 that's regularly parked on/near Powers Road in Seven Hills. Looks like a trailer was attached to it, or it was very closely parked to the tow hitch on it.
That's generally where you are going in a hearse
Son and myself (C34 and M35) turned up at the daughters house and neighbour she was talking with said "Here are the two White Lady funeral cars arriving"
  • Like 2
Spotted Josh aka "Brick" @ my work tonight swapping exhausts
Really?
I actually had some respect for him, as I'd assumed he did it in the apartment parking space.
You've made things too easy for him Dave.
  • Like 2
Silver NM35 spotted lurking around garage sales in Wentworth Falls this morning.
Yes, I spotted it too? at the Old Bathurst Rd roundabout near the Blackburn Hotel in Katoomba yesterday. I waved to the driver as I turned off the roundabout and received a nod in reply.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
