Spotted a black M35 (followed by a black R34 GTt) leaving the carpark of the sports grounds at Masonic Schools Oval in Baulkham Hills. I was getting into my dark green C34, this was right around 9.45pm or so...
That would be me. I play touch footy there most Thursdays.
Spotted and drove past a white s2 C34 parked on Lucas Road in Seven Hills (right near the roundabout where it changes to Sackville Street, in the school zone) around 3.30pm today. Rego was BBE76K or something similar...
Spotted a pearl white C34 s2 this afternoon heading west on the Great Western Highway near Mays Hill/Westmead (can't remember exactly), around 3pm. I was driving my old man's car heading in the opposite direction, towards Parra.
spotted Silver S2 on Peninsula link towards Mornington tonight at around 10pm, was driving the Mrs Newbie Beetle. Shame I wasnt in my stagea, saying that if I was I wouldnt have spotted the s2 as Id have been half way home by then :)
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
