white RS4 yesterday in driving from chatswood - gordon, tried to have a look at the driver, he didn't make any eye contact so couldn't wave. B-side (or similar) sticker on back window.
Maybe he didn't look at me cos I was driving a civic
Spotted Sat morning around 8:45am in Centro car park Emu Plains NSW one white NM35 with aero front bar, side skirts, roof spoiler and Standard wheels.
It had a Nismo sticker on the rear right of the tail gate.
It was parked next to mine.
Now I see how low mine is comparing to standard height one.
Must post photos to "what have you done to your Stagea' section soon.
Installed BC BR coilovers, toe-in and camber pins to rear to fit -3 degree camber.
White s2 on oconell street, dolphin grill???
Very nice note and intake! Gave a wave outside outback jacks. Think I missed you though! Very jealous, as a p player I've only got the exhaust note and even then it's a bit of a drone.
Spotted yesterday....
black C34 GWH Leura NSW going East around 3:20pm. Gave a :action-smiley-069:
silver M35 east bound after Cumberland Hwy on ramp to M4 around 4:30pm turned off James Ruse Drive. Gave a :action-smiley-069: bit shocked to see another one??
Spotted an '03 M35 (that looks in ok nic) being wrecked for $25 in Adelaide on Gumtree.
Link: http://www.gumtree.c...king/1003055156#
Surely this sort of thing wouldn't happen to a C34.. ;p
Bayside blue c34 stag on tapleys driving behind me. Looks so tough in blue! Also
Saw another one
Same colour on well dished rims parked near Westfield Marion somewhere!
and neither of them were me...
Spotted a white M35 at the shops at Point cook around 7pm and a white C34 on the Eastern freeway Sprigvale road off ramp coming home from purchacing the new Audi A4 quattro.
That make 3 AWD cars in the driveway now. :)
I never saw a bayside blue stag till today.. Then 2 in a row but it could of been three!
In that colour they look so good! Thought there wasnt many about in adelaide!
There are only 3, maybe 4 I know of.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
