  • Replies 47
All i know is that no matter what sort of day ive had when i get in the Supra and drive home it still puts a smile on my face. The only reason i get up to go to work is that i get to drive the Supra there. But im lucky i dont have to leave it in public places if i did i would probally have a bunky for work also
i luvvvvvvv utes.
Yeah you n Memphis can accompany each other to B 'n' S Balls ........ quality!!
:P
Modifications: Roo Bar, Over sized aerials (at least 3), Giant Spotties, OBH Stickers, "honk if your horny" sticker, "Real men drive utes" sticker, Set of giant truck mudflaps.
*waits for flames*
You guys are need to sort out what your doing.
I know a lot of people that feel like getting something else totaly outta the water, like a shitty ford ute , but in that case, sell now and DO it, dont wait any longer or think about it. You have to be a car enthusiast to own a skyline, or else youve just got it for transport or showing off.
When I feel its time to move onto another car, I am considering a Mitsubishi 3000GT or as a new car, maybe a decked out Liberty GT. sure they not the lightest or the fastest, but its something different and more upmarket.
If money wasnt a problem, id be looking into a Porsche 911 turbo :P
i totally know how you feel hey!
i dont even hav a turbs skyline and sumtimes i think why do i bother going through so much trouble i mean really, u pay high insurance high running costs your constantly modding it and to make things worse im a poor student so i cant work fulltime coz im studying id hate to think how much richer id be today if i drove a piece of crap or sumthing
but...............ill always love skylines and wud neva sell it except for another 1 :P
and BTW i had my badges ripped off like 2 weeks aftr i got the car from then on i knew that low life scum will always be out there ready to break into your car or scratch it or wateva which is another pain because you always hav to watch where u park my pet hate is people who dont care if they wack there car doors into your car in carparks
I know how you feel driver!
Someone badged my S15 in my own driveway during the day!
I've since sold the car and am probably following the same suit as memphis and buying a XR6-t ute and will be unichipping it as soon as I get it :-)
PS: Get a S15 Kim, you'll love it! I certainly did!
exactly, phucking lowlife don't give a damn about other people's property :hellpisd: . try parking new newer and expensive car like a merc or bm as much as you can, there tend to be more careful not to scratch their car than anythin else. i've got a dark coloured line and right after you washed it u see all this parking dings and dents and find new ones, which pisses u off big time!
by the way if i were to replace my line i'd probably go for a rexy or just an upgrade to a r34 gtt. but still damn those xr6 turbo ute looks hella hot! :Paranoid:
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
