ATTESSA - what do i fill the reservoir with... and where to get it?
My ATTESSA reservoir in the boot of my 32 is low... what fluid is it (and don't say it is ATTESSA fluid!) and where can i buy it? Is it a tranny oil or a P/S oil or none of the above?
Cheers
Accordng to the factory WS manual it uses "Nissan Power Steering Fluid Special"
At a pinch you could use ATF.
  • 2 months later...
Most people use a Dexron III compliant ATF for the actuator. Technically, your not meant too: you should use only Nissan Power Steering Fluid Special (NPSFS) according to some heavyweight at Nissan Japan.
Speaking to SydneyKid, he said the only reason for this is because NPSFS is designed with snow/ice condition in mind.
Anyway, I was just wondering if anyone actually managed to find NPSFS and how much it cost (for interests sake).
LW.
The Nissan Special Power Steering Fluid is Nissan Matic D which is their ATF. I got a few litres of it for $20 from Nissan spare parts in Canberra. I cant remember exactly how much it was as it was 12+ months ago now.
What is the best way to bleed the actuator oil?
For interest sake, here is what the guy from Nissan Japan had to say:
1. Transfer case fluid
Nissan Matic D is strongly requested because high torque is applied to
transfer unit.
2.. Transfer case (ATTESA E-TS-PRO Actuator) : It is not acceptable to use
DEXRON III fluid.
> Only Nissan Power Steering Fluid Special use is required.
Today I received the technical information from our design department.
1. The difference between the DEXRON III and Nissan Power Steering Fluid Special
The viscosity characteristic of Power Steering Fluid Special is lower than that of ATF DEXRON III and the resistance to wear is also improved. Each viscosity is the same level at 100 deg.C and the former viscosity is designed to have the lower value for under 100 deg.C than the latter viscosity.
This characteristic is aimed to rotate an oil pump located in ATTESA PRO actuator easily at the extremely low temperature (Around -30 deg.C or -40 deg.C)
2. What will happen if a customer puts DEXRON II or DEXRON III into the ATTESA PRO actuator reservoir in the trunk ?
The 4WD performance will be largely decreased at the low temperature because the viscosity value of DEXRON II or III is extremely high compared to that of Power Steering Fluid Special; As the rising characteristic of 4WD torque transfer becomes worse, it takes the longer time to transfer the driving torque to the front wheels. There is a possibility that the 4WD cannot be achieved in the worst case.
My understanding is that Matic D is "Nissan Power Steering Fluid"; "Nissan Power Steering Fluid Special" is different again.
LW.
Nissan Matic D is Nissan Special Power Steering Fluid. Ill find the bottle if I still have it and take a photo.
Its what Nissan reccomend to use, its easily obtainable, its not stupidly expensive so I dont see any reason as to why youd use something else.
  • 7 months later...
There are 2 bleed points. Put the car up on stands and start the engine.
The first bleeder is at the rear of the transfer case it will bleed itself when the nipple is opened. The second bleed point is much tricker it is above the half shaft right up on the chasis.
Nissan Matic D (Dexron II/III analog as i think), Nissan PSF and Nissan Power Steering Fluid Special are different fluids.
See http://www.nissan-sp.co.jp/oil/ for details, there are some pics of OEM fluids on this page. It`s written in japaneese, use online translators for reading.
The p/n for Nissan PSF Special also known as "attesa operating fluid" is: KLF30-00001 or KLF30-00004 (the last figure is for can capacity in liters).
While preparing to manual conversion I`ve ordered 4l of this fluid at auto.vl.ru -- i`m not sure this link can be usefull outside of Russia, but you can try to order it somewhere in Japan using the right partnumber.
no the wheels don't need to turn the atessa pump has pressure as long as the engine is running.
And for what its worth we just use a synthetic auto trans fluid and it has always worked fine including races and targa tas
i hav a r33 gtr and a-lsd light turned on, i had to turn the car off n on again for it to go away. this happened once in a while then more often. i gather it was getting worse until it just stayed on. found out that the pump was dead, openened it up to find the one of the magnets was broken and three of the four brushes were completely worn out.
i bought a second hand unit which fixed the problem but it started to hav the same symtoms again. i gather that the replacement unit is also 10years old and cant be much better than my old one.
i hav rung up nissan and nearly died when they told me its gonna cost nearly 6 THOUSAND dollars !!!! just to buy that part.. my problem is i cant find any place here in melb or australia who can repair it.
i also noticed sumtimes when u turn the key to acc i can here the 4wd relay ticking endlessly.
will try to plug in dianostics but unsure if that can identify any problems or electrical faults.
any suggestions ????? confused....
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
