Right, click on this link Fuji Corporation and they've got Work Emotion CR Cai 18x9.5 with tires front and rear for R32 GT-R for 140,000 yen... Fuji Corporation have some pretty good deals on new wheels and tires.
Otherwise, if you really like my wheels (Desmond Regamaster) you could go for these:
158,000 yen with 265/35/18 tires at www.hokuei-inc.co.jp
Are these the same? :
http://img165.auctions.yahoo.co.jp/users/4...4dsc0060011.jpg
  • Replies 84
LM's are made by Rays under commission from Nismo
I reckon they're a 5-spoke of the TE37's
http://www.rayswheels.co.jp/cgi-bin/cgi2/g...O&model=010_GT4
http://www.rayswheels.co.jp/cgi-bin/cgi2/g...model=020_GTMAG
They also have a different pattern around the studs (many holes, rather than either 4 or 5 on the TE-37).
LW.
It's actually the overall rolling diameter that needs to be the same front-back to keep ATTESSA happy.
Just thought I would emphasize this as I see so often people saying AWD needs same width rims.
The torque split controller works on the rolling dia. and even pulls in if one of your tyres is a bit low on pressure.
So on diff size rims just adjust the tyre aspect ratio and rolling dia. to suit!
IMHO rim apearance and desirability is totally subjective.
A big issue to me is how easy they are to keep clean!
Here's my car with BBS LM's in 17x9. I dream of 18inch wheels though for my car. Either WORK Meister S1's, R34 GT-R wheels or Nismo LMGT4's and I'd still settle for TE37's.
I might have to sell these rims as I just bought some Brembos for the front and it doesn't look like there's enough clearance for them :D So, great excuse to upgrade wheels I suppose!!! I'll need about $5k though to get what I really want! OUCH!!!
Hey thanks people.
Right now, I'm looking at this :
http://rayswheels.co.jp/datas2/VOLK/060_TE37/logo.jpg
in black like this :
http://rayswheels.co.jp/datas2/VOLK/080_TE37M/logo.jpg
And I want 18".
I know the size has to be the same for all on a GTR, just wondering if they could also fit on a 300zx as well?
thanks again.
And I want 18"..
That's actually dark blue you linked. 18" TE37s in black/dark grey looks like this:
I should know: those are my wheels in that picture. Hopefully they will show up some day (currently still in Japan).
LW.
justinfox: yeah, they look great, you just need the hubble telescope to see them from Australia :) Hoping I can get them here (without being pinched by some arsehole in the next month).
Its apparently a special order colour that Ray's offers (another one is Mercury Silver, but those a *freakin* expensive to get, even by TE-37 standards).
Yeah, they will be going on my (Gunmental) R32 GT-R. They are 18x9.5 (which apparently fits without rolling), and I think the offset is +35 off the top of my head but I can check if you like?
Should look a little something like this (though the wheels are a bit darker IMHO):
LW.
They look awesome.
Lucien, I thought GTR offset was closer to +12 or +15, with a +35 for GTSts? eg. if you bolt on a R34GTR wheel to a GTSt they stick out too far?
Also, what are they costing you to send from Japan?
Cheers
Ronin: Your right. They are +12. Its been so long since I bought them I had forgotten :D
Edit: To cut a long story short, I payed to have them afixed to my GT-R, but the place didn't do that, so car is here (with original GT-R wheels on :) ) and wheels are still in Japan. Hoping to get them brought across in another vehicle, but waiting for the place to get their act together.
LW.
IWells,
Those rims look great!
My car is exactly the same as yours, I have the SSR mags at the moment, but will definitely go the RAY route.
I'm a bit confused with some of the RAY wheels, I believe the spokes on the TE37 is flat, but another version has them slanted inward. Which is which?
BTW, Hope you get your wheels soon and safely.
Informer: The original (and still the best IMHO) TE-37 has the slanted spokes. There are a couple of other versions: the flat spoked version is the TE-37M; there is a TE-37 gravel that is also quite flat; TE-37 Cup which has inverse slant, and TE-37 K which is sort of a dished version of the 37M.
See: http://www.rayswheels.co.jp/cgi-bin/cgi2/g....cgi?maker=VOLK
LW.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
