that's awesome news Leigh!!! so excited for you!!
are you gonna tell us the suburb? i told my mum you & Fi wanted to buy her Curtin house :rofl: but couldnt talk her into selling lol
i can't believe how quickly you have to move these days... and u can't even bargain anymore! so if you paid the asking price, does that mean the guy with the extra $5k was going to pay $5k over the asking price then..
Thanks Shell sending a pm to you :laugh:
Yea he was going to pay $5K over the asking price to try and get it. Luckily for us as i would have matched it again as it was still good value at that price.
Leigh
So, i actually got to work today wanting to clear my current work load so that i could do something more interesting.
But instead of that, we were locked out for half an hour and now only the internet works. No network = no work.
Oh well, i guess i'll just have to drink coffee and surf the net until the server wakes up.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
