Prue you should try to find yourself an EA position in a public service org like Centrelink/DHS/Medicare. You'd almost certainly be located here in tuggers, and it's practically a glorified secretary :P that, and you'd be hard-pressed to even find one lower than APS4
I used to work over in Woden for the department of health & ageing & apparently they're going to have a shitload of EA positions opening up soon so my dads going to send me all the info when it comes out.
Hello territorians,
I'm trying to contact OKBANANA (Dallas S), as I purchased a R34 Alternator My link from him over a month ago and after confirming that he had sent it, then said it was returned to his house, now he won't answer his phone, emails or text. I realise he works for the government and works away on occasion so I'm trying to give this the benefit of the doubt, but dead silence is not helping.
Maybe someone on the forum/ACT area knows his situation??
Thanks
Pretty sure he'll sort it out and be back in contact as soon as he can.
He's not on here often. Last post was around end of Feb when he mentioned some work to be done in 3 weeks time.
So I'd say after the 21st sometime.
It's possible he's away at the moment, only on the last page of this thread you can see he was looking for anyone to help him with removing the engine from his car but not until 3 weeks time. Also he doesn't strike me as someone to rip another person off, seems to have a good forum standing so why would he ruin it?
Best of luck though, hopefully he should read this asap and contact you :)
Just noticed I'm a bit of a Postwhore without the post
Here comes the Rain, lucky I'm inside with a cold drink and some choice music.
Better put the roast pork on or there will be no crackling...gotta love that crackling Mmmmmm
Bored?.....yeh just a little :cheers:
Thanks for the update guys, we'll wait till then and see what happens!
as in the angle???
mine are shocking, so dim its not funny and they look horrid on lo beam cant see anything. hi beam goes well though...
as for adjusting...no idea...but from everything i have seen the clips are more of a one position only???
Yeah, sorry, should have been more specific. They need to be adjusted up.
There are tilt screws on the back, but they dont seem to be doing anything?
This afternoon was really shit on the Tuggers express way coming home. The anger mgmt sessions did not help me cope with the congestion caused by 2 big tractors in the right lane and a bunch of f**ken hopless arsehole muther f**kin dream boats in cars without a clue of how to overtake on the left. Grid lock from civic to woden - Vent completed
:rant:
PS. Did you know CNUTS displays as "dream boats" LMFAO
Edited by Sinista32
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
