:thumbsup: to Kudos Motorsports.
Orderd a new Brake Master Cylinder last night. Received prior to lunchtime today. F#cking awesome.
I called Andrew at Kudos yesterday lunchtime and asked if he had one and if so to get it to me quickly. He rang me back in 5 and said yep got one and as soon as you cut an order I'll post o'night express. Expect Tuesday if you order at night.
So orderd last night and it was waiting for me when I got home :D
Cars going in this afternoon to get another pressure test.
Wish me luck!
The coolant just keeps disappearing and I cant find out where the hell its going.
Engine stays cool all day every day.
Still hearing the gurgling behind the dash even after trying the things the mechanic told me to.
Fingers crossed its a loose hose!
Checked for both of those thanks guys.
Had a long inspection in and around the floor and under the car.
Did a few short and long trips and checked for puddles after.
Nothing and no signs under the car of anything going wrong.
Car feels really weird to drive cold. (I am probably just paranoid as I have only ever driven an auto 323 lol)
Dont know if thats just normal as its cold.
By weird I mean changing gears isnt smooth as it kind of slugs into each gear.
idles around 1100 then drops to around 900
I dont know hey will just have to see what they say when it comes back.
Dropped it at Ultra Tune Fyshwick as they could get it in for a test today for $50
Lol sounds like it would have been an epic stack.
I'm 24 and my right knee is destroyed from my many rollerblading fails.
I guess us young guys aren't as bulletproof as we'd like to think hey haha
Guessing we need to drink more milk!
I got the car back just before.
Turns out there is a leak from the actual radiator
+ behind the engine right up against the firewall some small tap thing that is extremely hard to get to
They suggested getting the radiator reconditioned
But I think I might just purchase a 2nd hand one or even a brand new one.
haha yeah was pretty f**king funny....wasn't even getting big air though lol. I had my helmet cam ripped off its mount and buried in the snow......it wasn't filming at the timestupid.gif
We estimated the ditch my head dug into the snow (relatively untouched, definitely NOT powdery haha) was about 50cm long and 30cm deep. When I was able to get up and hobble the 50m to the next T-bar, I decided I'd lay on the snow for a while to not further strain whatever I'd just done to my back....lay there for about 30mins before I could stand up confused.gif
I drink about 1L per day hahahaha....I don't think I have a calcium deficiency :P
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
