LOL - that is exactly what happened when I went there last night - my reaction was the same as yours.
I'll take the kids to the house the Shell suggested and a few other ones northside
We tried to go last night but the traffic around there is f**king stupid we couldn't get anywhere near it so we gave up.
So I called around to get my shocks installed into the car.
They already have the springs everything in them.
Everywhere I called wanted $400-$500 thats insane!
I was just being lazy as it took us around 2 hours to do it when we took them out.
Was more thinking around the $150 mark
One guy told me it would take 1 hour 30min per shock!!
I wasnt asking for a coilover install and tune lol
I managed to get 2 free movies in Woden last night. :happy:
Signed up for a membership and got a free ticket so I went and saw Happy Feet 2.
Then once that finished we noticed another movie going in so we hung around the toilets
and snuck into what turned out to be Sherlock Holmes 2. :ph34r:
LOL smooth shit man :P
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
