Did my p offs today. Slowest 3 hours ever and the majority of everyone there were obvious hoons
When they asked everyone why they're there, was it any surprise the amount of people that answered "because if I don't do this I lose my license"? It's bullshit that you don't lose the points until you pay the fine, coz that means those kunce have a chance to gain 4 more points before they lose their Ps domokun.gif
I'm heading overseas in April for a couple of months and doing the whole 'saving' business. I'm heading around Asia.. so I don't need to save toooo much, but I still want to be able to spend with confidence.
The shitttyyy thing is that whenever I log into SAU someone is selling something which i really need/want, but I hold off from buying it.. fk u guise! (in the nicest way possible).
Maybe I should just go nuts and buy all the car stuff in Asia and just get them shipped back here. lol
True Chris and I should too. I'm too old to be mixing it with the new young bloods.
The forums are good for knowledge and parts, thats about it nowdays.
Having the GTR running sweet and looking good after sooooo long over excited me.:/
Tissue please
PS. Just going for a drive up there and watch for an hour or so. It's a mixed bag day by the looks of things including superTT's
Half the time I think about selling my car myself, Still a great car to drive and puts a smile on my face when I drive it, but its been such a money pit. Which is why so many people have gone I suppose.
yeah heaps of people said that, except apparently now that doesn't work since that's what everyone did so now points are taken straight away - only a rumor though
If you guys are bored we should do a regular cruise on a good road like the twisties and up to Blundells flat (the end of the bitumen on Uriarra rd).
Plenty of good spots for a picnic too.
When i rode sportbikes this was very popular and heaps of fun cos you just go at your own pace.
If yous wanna have some fun ya gotta get off your ass and do stuff!
Dunno if my opinoins valid seeing as im nearly 40 and i still like Lego and Playstation.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
