Fixed the stupid window motor, after so much un screwing, screwing, cutting my fingers and swearing at shit. I gave the motor a good bang and got the window up.
Someone please remind me next time my car screws around drive it into my house please
  • 4 weeks later...
I believe lee and Thomas auto elects in Phillip stock Phillips headlight bulbs etc.
Also though this was epic, watch the vid in the link, http://www.shockmansion.com/2012/03/16/flares-banned-at-soccer-in-the sphincter of the universe-problem/
Done - Saturday suit you for Pick-up from mine ??
I'll make sure to be home. Karl has a short temper, easily set off. Tends to start swinging at anything and everything, punching small children etc. Dangerous guy. Definitely require backup.
Im just arriving back in Canberra after driving the great ocean road all the way to mount gambier then back to Melbourne... We went in the r30 hatch and i don't think there is a car i would have rathered :-) it didn't miss a beat the whole way and its damn comfy... Im so proud of it!
The only downside was that a semi decided to drive into the back of it at the road works :-( but the damage is very minor given the walking pace speed.
LOLWUT!
I have AC chilling my GTR finally! (Just in time for...... WINTER)
So you know in case you want cool.
$365 for a Retro fit and A/C service
Out with the illegal gas and in with the new environmentally friendly.
I'ma Greenie :action-smiley-069:
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
