Not sure on his real name. His facebook had a fake name.
this appears to be the new one.
Yeah his name is Alex. I complained in this thread about him not all that long ago (search for last 3 digits of his number plate).
I know exactly where he lives too lol
Troy pm me his address?
And is he a drug dealer or some shit
Maybe he's the guy in richo who got his skull caved in very early this morning by a group of fella's.
Not that I would wish that on anyone.
However - it's comforting to know that drug farked scum look after their own
I expect the guys that did the baseball beating will likely get a bashing themselves down the track. When they cant afford to pay for their habbit.
Pfffft.
I need more control over the visuals on this new virgin of SAU.
Legs crossed that we get moar powah after this weekend.
and perhaps I missed the notice for the upgrade -Stalin used to give more notice and he was a Dicktator !
I like Ash alot but seeing his face so much makes me invain :P
Ps. note to self, open can before attempting to drink it !!!!
ROBOTS!!!!
I've been working on a "mini segway" type robot. It's got 2 wheels, stands up and keeps itself balanced.
I added a servo to move a weight back on forth and incorperated my r/c car transmitter into to drive it around.
check it out!
Once I've figured out all the bugs (and have a few spare dollars) I'm going to build a full size segway to cruise around on :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
