Oh thrust me right now.
Carrots !
:laugh:
I lost 8kg in 6 months by Not eating the Dinner Leftovers and I Replaced my Smoko Chiko Roll with Fruit. :banana:
That is really all I changed.
My Cholesterol also went from High to Normal. (+ medication)
Blood Pressure Remains High. :mad::verymad:
On the Sleeping / bedtime thing, I am rearly in bed before 11pm and my alarm goes off at 5:30am, start work at 7am and finish at 3:30pm.
With the amount of waking hours spent doing someone elses bidding + the commute to and fro and the sleeping in preparation for another day of dedicating my time to someone else, I want as much of my own time as I can get.
Blood Pressure Remains High. :mad::verymad::D
  • Like 1
:banana: closet eater I am :D !
Office work has really put a toll on my eating - always going out for lunch and my work building is connected to the shops. I've been starting to take my own lunch again though :)
Interested to see where all the stolen bits end up.
Need to stay away from them. Stolen bits are cursed bits, and make your car unhappy,
Finally joined SDMA.
CAMS L2S as soon as i get my membership number.
Time to make the extinguisher bracket, and i think i need a better drivers seat.
You'll have to let us know when your heading out for a run. Only two minutes down the road :D
lol I wasn't having a go! Just giving you the infoooo!
Southern Districts Motorsport Association. You know when you came to Sutton Rd that time? Well they own a hillclimb next door.
changed my post to show sarcasm.
cheers :)
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
