Personally I don't
Brand spankers - $4000 without rubber. If you can locate newies.
Every so often they will do a run if the numbers are there.
I bought my 18 x 9.5 +12's for $4k last year.
Ones above have been resprayed.
You would need to see each one to check for gutter rash
no longer have the original Nismo stickers
the front one looks concave and the one in the back looks different (maybe optical illusion)
I think you can do better.
There was a silvers set up for sale recently that I believe is cheaper (if not sold). To suit GTT offset
Edited by Sinista32
how f**king poorly do your gutters deal with a bit of rain? Lakes everywhere tonight!
Probly a combo of not much rain lately (so not soaking in well yet) and all the leaves having fallen off and blocking things up.
I went through a puddle this arvo that would've been a good 15 meters long, trying to drag me into the gutter. (left side only).
Fight it and floor it. :D
  • Like 1
So, I have been invited by family to attend a "track day". To bring our cars out and "race" them around the track. Now, since this is a invite I can reject or decline - my main concerns are if I bring my car to the track I risk blowing something (Rosie is my daily). Once you see the line up - you'll soon discover an easy option for "you got no chance", however, since it's family it's more a fun thing and bringing the performance cars out in the family. Once you see the line up - you'll know I'm the baby out of the 4.
So the lineup for the day:
Uncle #1 Holden Monaro CV8-Z
His son; cousin - RX7 - Bathurst addition.
Uncle #2 Porsche 911 Turbo.
adv7.1_automotive_connoisseur_adv1_wheel
Me: R34 GTT
So yeah, no chance at all for me to even compete but I'd like to go out there and have a fun day,
but is it worth risking a breakage? (Are track days amazingly fun that even if you break something you're still on a high etc)
Do many things break when taking your car around a track?
anything I can do to prepare Rosie for as safe as possible run?
How many lap should I do before I start to retire the old lady?
lol who?
firstly you can beat all of them (except probably the porker), especially if you can borrow a set of semi slicks :)
seriously though....assuming the car is in good condition, do an oil change, have the brakes bled and keep the boost turned down, you'll have a ball.
I ran my old gtst (standard boost) at track days for years without any mechanical issues. Its only when you modify them that you have troubles.
# of laps are easy...keep going until the brakes fade or the water starts to get hot :)
  • Like 1
I don't know the RX-7 is twin turb AWD and the Monaro.. well I dunno - maybe in the corners :P
Anyways - semi slicks is a nice idea :) Sounds as if Rosie is going to live through it if I decide to go down. Boost is set to 10 PSI (low enough i hope) and everything else seems fine - might do a a quick service before I "track" ;) down. Thanks for the tips :)
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
