Would if I could, but I definitely wouldn't be buying a stock standard Skyline with the proceeds (Golf R would be on the books lol)...would need to be already modified for ~300rwkw or more, ACT rego, and come with a RWC before I'd consider another heartache :(
I'd never buy an R32 :P
Would have to be a very very very neat 33 GT-R (preferably series 3 and modded) or newer.
I'd consider anything with an RB25DET in it, if it were in great condition and cheap lol.....coz god knows the purchase price is only the beginning in this game
I know your feel bro. But now that mine is done. I couldn't care less on the price it cost. WE MISS YA TROY. Go buy like a standed s1 33 or a R32 Gts-t for like 3k just to have fun with :ph34r:
It felt a bit like that last time lol....running the f**king gauntlet of endless problems
It's never done. You know I'm right ;)
And f**k off don't tempt me lol....I just wouldn't enjoy a standard RB25 though :( would be all for blowing a couple of thousand on something I can thrash and enjoy, but for that price I'd never get something I'd actually enjoy :( and if I did, it's because it was well and truly on its last legs lol
Bike still scares me though, so at least I've got something fun to get around on....just want a ballsy car again though heh
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
