Obviously wasn't anything major or even newsworthy. They gave him a defect notice :\
anyone have or know where i can get a 1/8NPT female 90degree. looks like so fitting snapped on me and need this like tommorrow morning
Any suggests willing to pay premium if i have
looks like this
http://thumbs2.ebaystatic.com/d/l225/m/myseUTTgClWUSKxLOeN4ReQ.jpg
http://www.holley.com/data/products/pictures/large9914__.jpg
http://paceperformance.com/images/F20097791.gif
Any shops in Canberra that sell or make these
hmm if a barb fitting was sufficient, every pirtek has them in brass....but looks like you need a female dash fitting of some sort on the other end.
looks pretty specialist really....not sure how much luck you'd have in Canberra. Earls in Sydney would have probably have something in stock
Im tapping a map sensor to the manifold. The thread was tapped great but when I was screwing the sensor and the fitting it just cracked. Without the fitting the map sensor fouls on the throttle body. The image were just to give an idea.
OK...pirtek then. I guess the fitting cracked because it was too tight, remember that NPT is a tapered thread.
Also, are you sure it is NPT not BSP? they are dangerously similar....
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
