I must admit.. knowing it's 1am and I can still watch a movie is awesome ! However, not being able to drive Rosie is more heartbreaking.
Will you be getting another skyline once your R34 has sold?
I don't get home from work till 1am-ish so I watch all my TV now haha
Nah, need the money from the car for other things, but maybe in the future! I wonder when R35s will drop right down in price..... ;):D
  • Like 1
all good things take time
patience is a virtue
settle petal
a stitch in time saves nine
better to get it done right first time
anticipation is as good as the dream
blah blah
yeah I'd be pissed too Daniel. obviously your in a queue because the actual effort is minimal
Yeah the first response was that there was a hold up with paper work between DOTARS and compliance. Then I went and checked the car out in the flesh and the bloke said it was waiting to go up on the hoist and they have just been flat out. Most recent is that the paper work is completed and now they are organising rego etc for me
If anyone sees my skyline or knows who bought it text me on 0423402784
mum kicked me out of home and I got a text from my aunty saying that mum sold my car
Without my signature on the rego papers
if anyone sees him or knows him get him to call me ASAP
Unless I can get my baby back mum will never hear from me
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
