phone LCD screen replacements
anyone know who/where does this and can be trusted ?
I have 2 HTC Mobile phones where I have cracked the screen
These are worth $450 and $650 bucks so I'd like to see if I can repair them
all help appreciated :)
I've done it before on HTC depends which model it is I can probably do it for you. Sometimes you have to get the LCD plus the digitizer because it's nearly impossible to seperate them.
You can try the phone shop vendors in tuggers mall or Woden infront of Vodafone
Soda blasting was used on my GTR bonnet. Very gently but still managed to rip a whole in the alloy bonnet.
I think in the hands of an experienced operator it has it's benefits.
I expect rubber and sills need to be covered correctly or avoided.
Ive always done my cars prep by hand. The whole lot. Takes a long time but you get better results. Hope damage was not too bad Mik.
The rubbers can be fixed, they are old and hard and can be sanded back, maybe thats why the soda did that.
The plastic bit in the back window seal is fked anyway, i might cut it out and do a bead of sealant in the gap.
So in hindsight, you can sand just as close or closer than you can blast, and blasting lifts the rubber and leaves crud under there.
Im glad i only did a couple of spots, ill have to clean behind the rubber to get it sitting flush again.
Its good for getting paint out of the tight corners, and probly good for cleaning small metal parts
Its not working properly, the guy sent a bag of the wrong soda, so it clogs up. It works with constant shaking, but thats kinda hard to do while your trying to use it.
I cant get blasting soda in canberra that i know of, and the car will be primed before the right stuff turns up....... :/
Maybe ill do the old wheels or something.
Caught up with a few mates and went for a quick cruise - they met up with the Braddon guys... left there not wanting to be around kidz doing fatty skiddiez. So went up to Mt Ansilie and chatted about Initial D with a m8 who tagged along then went home. So good taking Rosie out for a long nip :)
Spotted a R33 GTR and a white R34 GTT and about 50 SS's haha
Edited by RosieR34
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
