Cool. Any idea the best place to get one? Closed my door when I got home and the window exploded!
That is Crazy! Do you think it was touching something hard inside the door?
or maybe too much air pressure inside... Seals too good.
Trojan? or whatever JapSpec turned into?
or Try Jap Parts in Fyshwick maybe...
Damian 0449775209 -
Ph: 6280 0606
Ah: 6280 8898
Tell him Rob with the R31 Wagon sent ya! :thumbsup:
hmm that is strange....I agree it seems likely it either hit something inside or maybe the lower seal is rusted/loose?
anyway, if you find a window in Sydney I can bring it down next week.
Bub wanted to get up at 5 this morning.....
Lucky he did, i found water spreading across the lino floor.
One of the fishtanks is leaking. Emptied it out, fish in a bucket, took it outside.
Good excuse to get rid of it...... dont tell the missus i said that. ;)
less fish time=more skyline time
Anyone want a pair of Angelfish?
Edited by D.I.Y. Mik
I once had an old Pintara as a daily that someone smashed the window on. We got the window from the wreckers and I can't remember it taking Pete more than a couple of hours all up to fix?
Different car but still Nissan with all electric bits etc.
Surprised also if there's not a tutorial on here how to do it somewhere.
Hi Eric - have done it twice on my 32
It's not complex at all but the first time will take 1-2hrs. It's mainly about the angle of getting glass out/in.
Make certain you give it a great vacuum if the glass has shattered.
It gets every where but particularly on the brushes and inner/outer window strips
Which means if you don't do it properly your new (2nd hand) window will scratch-up the first time you put it up/down.
It's 10 minst to get the door card off and all the window switches out and unplugged
bout 10-20 to undo the nuts holding the window in
bout 10-20mins removing the window - but if yours is shattered just the thourough vacuum and removal of broken glass.
I did it alone but it would be a lot easier if there are 2 of you. Just balancing the window, slotting it in and doing the nuts up whilst the other holds the galss in place.
TFE mate.
$150 for a window and $300 to install it.
How hard are they to install? Anyone have any idea?
Cheers.
It wont be too hard would just need 2 sets of hands to do it.
I might be able to assist tomorrow night if you need
yeah DIY is very do-able, cleaning it out is the pain as said above. Also check for rust in the channel that holds the window, and also rust or damage to the "waist mould" that goes along the top of the door.
the only other issue can be adjusting the window afterwards (we had heaps of trouble in the 350z) but I think a 33 should be old enough to just do a straight replacement without any annoying adjustments.
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
