Cool. Any idea the best place to get one? Closed my door when I got home and the window exploded!
That is Crazy! Do you think it was touching something hard inside the door?
or maybe too much air pressure inside... Seals too good.
Trojan? or whatever JapSpec turned into?
or Try Jap Parts in Fyshwick maybe...
Damian 0449775209 -
Ph: 6280 0606
Ah: 6280 8898
Tell him Rob with the R31 Wagon sent ya! :thumbsup:
hmm that is strange....I agree it seems likely it either hit something inside or maybe the lower seal is rusted/loose?
anyway, if you find a window in Sydney I can bring it down next week.
Bub wanted to get up at 5 this morning.....
Lucky he did, i found water spreading across the lino floor.
One of the fishtanks is leaking. Emptied it out, fish in a bucket, took it outside.
Good excuse to get rid of it...... dont tell the missus i said that. ;)
less fish time=more skyline time
Anyone want a pair of Angelfish?
Edited by D.I.Y. Mik
I once had an old Pintara as a daily that someone smashed the window on. We got the window from the wreckers and I can't remember it taking Pete more than a couple of hours all up to fix?
Different car but still Nissan with all electric bits etc.
Surprised also if there's not a tutorial on here how to do it somewhere.
Hi Eric - have done it twice on my 32
It's not complex at all but the first time will take 1-2hrs. It's mainly about the angle of getting glass out/in.
Make certain you give it a great vacuum if the glass has shattered.
It gets every where but particularly on the brushes and inner/outer window strips
Which means if you don't do it properly your new (2nd hand) window will scratch-up the first time you put it up/down.
It's 10 minst to get the door card off and all the window switches out and unplugged
bout 10-20 to undo the nuts holding the window in
bout 10-20mins removing the window - but if yours is shattered just the thourough vacuum and removal of broken glass.
I did it alone but it would be a lot easier if there are 2 of you. Just balancing the window, slotting it in and doing the nuts up whilst the other holds the galss in place.
TFE mate.
$150 for a window and $300 to install it.
How hard are they to install? Anyone have any idea?
Cheers.
It wont be too hard would just need 2 sets of hands to do it.
I might be able to assist tomorrow night if you need
yeah DIY is very do-able, cleaning it out is the pain as said above. Also check for rust in the channel that holds the window, and also rust or damage to the "waist mould" that goes along the top of the door.
the only other issue can be adjusting the window afterwards (we had heaps of trouble in the 350z) but I think a 33 should be old enough to just do a straight replacement without any annoying adjustments.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
