I was told if the clear is peeling, like on the mirrors, there is a problem with the paint.
You never know what the problem is, it could even be the primer, so you have to strip it all off.
Thats why i stripped my car to metal, and im glad i did, there was a mix of acrylic, 2 pack, and who knows what else.
From what i can see, its different on the bonnet. Lets hope so, or it will be expensive.
The colour matching should be good as its not metallic, but because its red, it gets attacked by uv the most and will fade quicker than other colours.
So you might get a small missmatch in colour after a couple of years.
Thats why paint problems really suck, because you know it will need a full re-paint sooner or later when it starts looking crappy again.
  • Like 1
Respray the Mirrors and Bonnet BLACK! (no colour matching required)
Get your wheels Powder Coated Black or White.
Would Look Awesome. :thumbsup: and gain 50 - 70kws. :woot:
only 50 you'll need fluffy dice to get 70 out of it ..... :closedeyes:
But love the thinking Rob, very logical solution ... do we go matt black? I'll pick up some cans (coz I'm old enough to get em with no Q's) ... you pick up the sandpaper .... into it! :D
Plasti dip costs around $30 a spray can. Different colours like paint but it's a plasticy rubber stuff that you can just peel off without needing paint stripper / sanding etc... SUPPOSEDLY won't harm the paint underneath. (although I've read of it happening)
https://www.plastidip.net.au/
Thats cheap cf vynil in the photo. Nasty stuff..... Oh your grille... oops
Well i do have a compressor and spray guns, etc. If you went acrylic i have thinners and everything. For plastidip youd need a special spray gun.
Aerosol is hard to avoid splatter.
Vynil is best done in summer when its warm. Very difficult when cold.
Black is a good idea, easy to do, cost hardly anything.
Waiting for wax to dry a bit....... too cold.
Edited by D.I.Y. Mik
Hehe rob <3
Yeah plastidip is weird.. Spray it on and it bubbles and does weird things and then dries smooth.. You just need to make sure the surface is really clean beforehand.
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
