Thanks RoB
cost a little bit more for the print underneath and not fully sold on it yet.
But seemed a good idea at the time (Impulse buyer) :)
It's Good! Slap an SAU sticker on there and it'll all make sense. :D
my view! ..... you don't need to make sense, many people ask me what my number plate means (THE34T) ... I say, if you don't understand it, you don't need to.
What does your number plate mean? hahahahaa
True. Never understood what THEEAT is supposed to mean, unless you're a food critic? :D
In other news. ---> http://www.gumtree.com.au/s-ad/dunlop/cars-vans-utes/1996-nissan-skyline-r33-4door-sedan-gts25t-turbo-rare-/1055461545
WTF is THEEAT!! .....
And that Gumtree link wont let me in, many women have a similar policy but what's going on with that site??
(( oh I guess that's the 3=E & 4=A thing!!!)) .... never did really get that, but ok, hehehehe...
Edited by THE34T
Seriously? Woh... Tis sad :( but also a little Excite to think of the possibilities. :)
Had a Very Nice sounding V8 fang past me this arvo. I started Mentally going thru various Carsales ads I have seen recently. :woot:
  • Like 1
Ahhh I see, I sorta guessed that what it was ... a sad moment indeed mate.
Can anyone tell me the best place to buy prescription drugs online without needing a prescription..?
Wat
Good luck with that. It's not exactly legal lol
Anyone wanna buy my van? Dead serious, I'm committing to a 2014 Golf R after taking one for a spin the other day with Reece. It's up on carsales/gumtree for $16k neg, but will do 14k flat if anyone from here wants it. Or find a buyer for me and I'll give you $500...lol like that'll happen though :P
Wat
Rofl, just taking the piss out of those spamming threads on sau in the last 24 hours.
I work at Canberra hospital pharmacy so I already know where to get my stuff haha ;)
I always think "THREAT" when I see your plates lol
Wat
Ooooooh jelly! They look so good... not cheap though!
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
