In all fairness, the servos just distribute the fuel they are supplied with, so sometimes it may not be their fault. I have some very interesting "diesel" samples at work, a few of which turn into the jelly when really cold!!!
Little bit annoyed.. Meant to take Rosie in for her SAFCII tune tomorrow, but I "busted" my knee at my first Gridiron game and can't drive it there -_-
Oh my... Not good Jeremy. :O
Bugger mate, you didn't kneed that (did I just say 'kneed'!!)
Do you live far from where you are getting the work done? perhaps under the circumstances they might send someone to pick up Rosie, after all, it's not like you will kneed the car back real soon. Is it worth a try?
  • Like 1
Shit dude. sorry to hear.
much pain?
Wasn't done at the Spears game was it?
Yeah, lots of pain :( Dr said 1 week, I am finding it hard to see this amount of pain go away after a week but... we'll see. We were versing Firebirds, the spears were before us.
you really funny m8 you kneed to chill m8
Usually find the "crap" batches are either full of white spirit or ethanol.
Or in my case today dirt and water
Leaky tank.
They had a problem at our local BP with the premium tank leaking, probably because they dug a huge hole next door and built apartments.
They cant dig it up for a while yet, so no premium is available at Jamison BP
When theres dirt and water in the fuel, its not worth going back unless they dig it up and fix it.
Jeremy: i have no acl in my right knee since i was 16. Trying to do motocross on a bmx.
There are many things i cannot do (footy etc) because of it, take care of it man.
Edited by D.I.Y. Mik
  • Like 1
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
