Thanks Rob, I'll check out their prices compared to the online prices
I have been taking my time with getting the 34 sorted sorry Zeb.
Lost a lot of motivation when I had no time off work to get it done.
As soon as it's on the road then I will start pulling the 33 apart for you and we can do some swaps :)
Just been watching some Old Bathurst vids.
30 year anniversary of George Fury in the Turbo Bluebird. I remember it. :yes:
Kinda miss my old '85 Bluebird, would fit in nicely with the SkyWagon and SkyHatch. :D
That's what I heard but it seems Next year will be the last for the Falcon.
http://www.abc.net.au/news/2014-10-10/fpr-confirm-falcons-to-race-in-v8s-in-2015/5804774
I'd love to see the return of the Many different makes and models like they did back in the day before the GTR made them all cry. :D
Lol at "pack of arseholes" :laugh:
Was a happy time.
Apparently it's Fords last Bathurst or something?
There won't be any factory backed falcons at this stage. Teams will still have the option of running the falcon until regulations change although they won't be financially supported by Ford
  • Like 1
Rob did you end up buying the new Pulsar and if so which model?
Starting to think about new options for a daily driver.
Hi Kat, yeah we got a 2013 B17 Pulsar ST Sedan (CVT Auto) with just under 16,000kms on it.
It's a Good, Modern, Safe, Quiet, Comfortable, Economical car and I find it Very nice to drive.
Great on the roads to Cootamundra. :thumbsup:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
