  • Replies 580
got this from ben @ jspec today regarding my car which was approved 15th dec.
"The next Kiwi ship has still not actually been added to the schedule although we expect it soon (I was told by someone at Kiwi that they were aiming for mid Jan) so the car has not had a place secured for it, however as soon as the schedule is announced we will book it."
So for the people who have recieved there GTRs, How are they?
I can only think of Lucien right now but there must be others. any pics by the way lw?
cheers
mark
(PS, just to be a pain, as it is now the new year, somebody was saying something about 15% less to pay now? is that still true? it would make the wait so much more worth it)
midnight: It got scheduled today. 19th of Jan.. They updated the schedule at about 10pm this evening. I'm on it :)
3 days and no email yet, I think I have to wait for a different ship as my car is in the sapporo port...
hey guys, have DOTARS realeased the finer details of the 15yr rule yet? I'm beggining to think that it might be easier to import through SEVS, hopefully the demand for imports will drop (from japan) and i might get myself a car cheaper.... but who knows...
Nothing has been announced publicly yet. They are warning against buying 1990 models (for import under 15year rule). I check the following site frequently for updates.
http://www.dotars.gov.au/transreg/vsb/vsb_10.htm
Depending on how much a RAW will charge you I can't see how it could be cheaper under SEVS?? I paid 825,00 for a grade 4 1990 R32 GTR, how cheap do you want?
thanks john :)
I can't say that i fully understand the 15yr rule changes that have been announced, i thought that only pre 89 cars would be allowed in? I want to import an r32gtst.....
from what i can gather, i won't be able to imprort a car through j-spec or prestige anymore, because it has to go through raws or somehting?? so confused lol *scratches head*
15 year rule is exactly that.. Cars 15 years or earlier may be imported and require an engineers rather than a full compliance system (SEVS) which is for vehicles that are newer than 15 years old. Its still in place, even though many haved predicted it would be abolished nearly every month for the last 6 months
So now its 2005, 1990 cars are eligible, for every month that comes up. E.g. a Feburary 1990 car can be imported from February this year. Of course earlier cars (all of 1989) can be imported under this rule.
Hi Jon. This car isn't grade 4, but it is interesting for price comparison purposes:
http://www.j-spec.com.au/list/index.php?ID=1657
Apparently that's around the price that most old GTR's were prior to the 15 year rule encompassing R32's here and in Canada.
IMO any savings to be had by buying an R32 that is not 'in-demand' would be lost after SEVS compliance costs - particularly so as there are so few R32 RAWS available. But that said, if it's the same price for a 1989 model and a 1994 model, I know what I'd prefer.
Mark
That's pretty cheap alright, what grade is it? Probably A with the accident history, depending on how minor. I wonder if a September 1990 will still be that cheap in September 2005 (providing the 15yr rule stays the same). I would expect them to go up.
I'd like to know how many of the r32 gtrs that are sold at auction come here with respect to the rest of the world.
predator, so dotars have told us what IS going to happen, but they haven't actually put it into place yet??- i thought they said as of january the 1st.... Hmmmmmm maybe i might just get lucky...
But when they do put it into place.... isn't it the pre-89 cars only??
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
