Hi!
R33gtst
just jap fmic
unifilter pod and airbox
3 inch dump and cat back
turbo smart single stage boost controller
12psi
hks fuel cut defender
195.3rwkw
stock turbo,injectors and fuel pump
dyno graph to come :happy:
big cheers to the guys at UAS - awesome work :(
Hi All,
I have a R32 with RB25DET with the following mods:
R33GTR FMIC
Full 3 inch exhaust and hi flow cat
HKS 2535 turbo
Wolf 3D engine management system
Upgraded injectors
Pod
Upgraded Fuel Pump
Its first dyno was on 12psi for 230rwkw, with the fuel leaning out, so am replacing the fuel pump and winding up the boost to 17psi. I will post results later on in the week when the work is done and the final dyno is run.
Silva32
:sorcerer:
r33 GTST
Remapped Nerve Essential ECU
HKS 2530
Splitfire coils
4" Magic Cat apexi exhaust
HKS pod
FMIC
Stock injectors
Stock Reg (will be up grading)
Stock Pump (will be up grading)
18psi
Edited by race_snooze
R33 S1 Manual
Stock bottem end and head
stock turbo
stock plenum
stock injectors
stock ecu
500hp tomeii fuel pump
3" dump to a big body high flow BOS cat
trust pe II cat back
gtr intercooler with some dodgey piping
metal intake pipe
apexi pod
catch can
turbosmart dual stage boost controller set to 11psi
209.5rwkw
new mods:
Greddy Profec B Spec II set to 11.15psi
future mods:
centre muffler taken out
slide r33 highflow
550cc injectors or gtr injectors
apexi pfc
im hoping somewhere over 235rwkw.
anyone know of good injectors GTR size or over that are straight drop in on rb25det? thanks
Edited by LTHLRB
Car: R33 GTST Series 1.5
Mods:
Walbrow GSS342 pump
Adjustable fuel reg
FMIC from CRD
Flyen 3' dump and 3' exhaust all the way through
$22 boost controller (spiking like crazy)
HKS Pod and intake
Stock Internals
Stock Turbo
managed [email protected] psi
the controller was spiking bigtime and then dropping off so it looks like time for a new controller, something good. The car pulls ok, but then hits a down spot and then takes off again. Goign to talk to the tuner see what we can do.
http://www.skylinesaustralia.com/forums/in...howtopic=137100
Update on the RBZ. Went back on the dyno last night and did some more tuning and sprayed some nitrous to it. Laid down 595 rwhp (~444 kw) on 93 octane. Still internally stock motor.....stock headgasket, cams, and everything. AFR around 11.2:1
JT
Stock turbo, hi-flowed
Trust Type M intercooler and piping
Apexi Power FC
Apexi AVCR Boost Controller
Split engine and dump from Hi Tech Mufflers (3.5"), racing cat (5"), HKS Super Drager catback (3.5")
Bosch 044 fuel pump
Sard Fuel Pressure Regulator
Pod filter
Splitfire coil packs
238.5kw at the wheels at 14 pound
Tuned at CRD - they are the bomb!
R33 GTS-T
Hi-flow Turbo
Apexi PowerFc + HC
Trust Turbo Back Exhaust + Split Dump
Bleed Valve Boost Controller set to 10Psi
ARC Sidemount Intercooler
Pod Filter + Cold Air Box
Made 281.4rwhp
The intercooler became a restriction at 280 rwhp so it was very safely and economically tuned at that point. Will upgrade intercooler at a later date and wind some more timing + boost into it.
Special thanks to Paul & Michael who tuned my car at Elite Automotive in Archerfield. I highly recommend Elite they are very good at what they do and fantastic to deal with. So if you in the area and want a good tune done they tune various ecu's so give Paul a call :laugh:..
If anyone has any questions please feel free to ask ill try get a photo of the dyno sheet up asap.
Edited by fEkuaR
Nissan R33 Series 1 GTS25T
3" Turbo back exhaust to twin 2.5" pipes
Apexi CAI
Bleed valve
JustJap FMIC
pulled 160rwkw on 4.5 - 5psi with huge misfiring problems. more boost + new sparks and a safc should solve this problem and hopefully be reaching ~ 200rwkw.
  • 3 weeks later...
1994 GTST S1
1st Setup
Stock everything except for
e-manage
040 Fuel Pump
Stock boost
HKS super dragger zorst
168.8rwkw
2nd Setup
Custom Turbo setup- small, 1-1.3bar at 3k - yipieee
Apexi Dump Pipe
VG30 AFM
Spitfire Coil Packs
730CFM Hi-Flow cat
Unifilter POD and cover
Emanage
Bleed valve
257.1 rwkw @1.1bar
3rd Setup
As second plus
AVCR
PowerFC
SARD 550cc injectors
Twin plate clutch
HKS Adj Cam gears
272rw KW
r33camgears.pdf
It's go live time. Thanks to the testers for giving the site a good shakedown over the last week.
Dyno Site
A few "rules" need to be followed:
1. Do not enter junk data. You can still view other people's graphs even if you don't have one of your own.
2. Do not sign up with crap details. If I see any dodgy logins created I will delete them, the car(s) and the dyno runs associated with those logins.
3. Do not forget your password. The password is encrypted in the database so I can't tell you what it is, and I haven't created myself a password reset page yet.
4. Report bugs to my email (zilla34 at gmail.com) with username and screen shots where possible.
5. Add suggestions for future enhancements in this thread.
Keep in mind, if this site gets abused I will pull it down.
Suggestions:
1. Sign up with the same username you have on SAU.
2. Add dyno type, location and shootout mode to dyno descriptions.
If there are any graphic designers who want to do some screen layout concepts send them to my email and I'll look at making it look pretty for version 2.0.
Willo.
Here's the page for entering your dyno data to compare it to other users.
http://sau.garagespank.com/login.php
And here's the url for talking about it, things which could be improved, results, problems etc.
http://www.skylinesaustralia.com/forums/in...howtopic=126563
way cool man...will add some details later
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
