R34 RB25DE+T
turbonetics stage 2 T3 to4 turbo ext gate
gtr fuel pump
nismo fuel reg
stock injectors & afm
emanage ultimate
jjr fmic
apexi super intake pod
turboback (2.5" dump/front & cat tho) catback is 3"
184 rwkw @ 9psi
Update:
3" dump/front pipes (still with 2.5" cat tho)
Profec B Spec 2
14psi
562.4nM
201.2rwkw @ 174KPH
just had a full retune.... (not a cleanup, full delete and start fresh)
car has:
hks 2835 pro s
greddy rb26 ex cam gear
3" exhaust
hybrid gt fmic
nismo 555cc injectors
nismo fuel pump
z32 afm
splitfires
bcpr7es @ 0.8
pod in box with cai
power fc
fc datalogit
blitz dsbc spec s
car made 280rwkw on BP ultimate 98 and 320 on united e85
very happy with the results as it's a very safe tune.... pulled 2 deg timing out of the top end and only lost 5kw, fixed all the cruise and idle issues, cleaned up a boost spike and got the car running absolutely perfectly.
my thanx again go out to trent & cat @ status tuning, who always go well out of their way to make sure my car is perfect! :)
all graphs are in sae correction mode so the results are the same as dyno dynamics in shoot 6
arias pitons
1.8mm cometic head gasket
spool H beams
arp head, main and rod studs
greddy inlet plenum
80mm throttle body
sard 800cc side feed injectors
040 pump
GT35R with 1.06 exh housing
Vipec ecu
tial 50mm external 'gate
nismo twin plate clutch and billet flywheel
splitfire coils
fully blueprinted
std crank
std head
std fuel pressure reg
+ probably other stuff i cant think of atm
BP ultimate
440 rwhp at 22psi (running out of fuel from the pump)
wasnt done in shootout mode either, was just while tuning, didnt get time for a proper run...
Edited by cuzz_33
1995 series 1.5 R33 Gtst stock internals
(vitals)
- GReddy T67-25g 10cm rear high mount, with external gate/screamer
- modified stock plenum, 90mm throttle body
- splitfires, NGK iridium sparks
- 660cc Sard injectors
- Power Fc+Hc, boost controller
- external 040, internal walbro copy
- Greddy front mount
- stainless high mount manifold
- HKS Pod
- 22-20psi
- BP Ultimate 98
303.6rwkw
(vitals)
- HKS Pod
- 22-20psi
- BP Ultimate 98
303.6rwkw
EDIT external bosch 044
Edited by R31Nismoid
1996 R33 GTST S2
Unopened RB25DET, 188,000kms
Splitfire coil packs
BP Ultimate 98 Fuel
Nismo 555cc injectors
Walbro 255lb/hr fuel pump
PowerFC
profec 2 spec B
FMIC
Mesh air filter with CAI
z32 afm
Garrett GT3071R
3" turbo back exhaust
Adj Exhaust cam gear
243KW@wheels
Previously on stock turbo, injectors afm & fuel pump was making 209kw @ wheels on 11psi
1996 R33 GTST S2
BP Ultimate 98 Fuel
PowerFC
profec 2 spec B
FMIC
z32 afm
Garrett GT3071R
243KW@wheels
Turbo Specs: Comp is .50AR
unsure of turbine AR, but either .64 (more likley) or .71 i have heard thrown around.
1998 R34 GTT
unopened RB25DET Neo, 80,000kms
shell Optimax 98 Fuel
stock injectors
stock fuel pump
nizmo Fuel Pressure Reg
powerFC
greddy boost controller
hks FMIC
hkd pod
z32 afm
Garrett GT3071R
3.5" turbo back exhaust
261KW@wheels @15psi
1996 R33 GTS25T S2 - 92000km
STOCK TURBO
Z32 ECU - NISTUNE
FMIC JJR RETURN FLOW TYPE
K&N PANEL
EBC - Bit under 12psi
3 INCH EXHAUST
SPLIT FRONT/DUMP
187rwkw
Cant say i was over the moon with the result. Oh well.
R34 RB25DET NEO (In R32 GTST)
3" Exhaust
Front Mount
Stock everything except for fuel pump
Adjustable exhaust cam gear
BP Ultimate
Greddy Profec B Spec II (12psi)
Pod filter
Nistune ecu
Stock boost/tune then 12psi and nistuned.
Edited by Hibino
R34 GT-T
RB25DET Neo
Fujitsubo Turbo back exhaust
Apexi Pod Filter
i think stock boost 7-8psi, was a dyno day so dyno operator didnt get time to get boost reading.
Standard ecu, turbo, smic
BP Ultimate
167.1rwkw
STOCK TURBO
Z32 ECU - NISTUNE
K&N PANEL
3 INCH EXHAUST
SPLIT FRONT/DUMP
187rwkw
Upgrade Fuel pump and Z32 Airflow now has 207rwkw on a touch over 12 psi! same dyno. now im happy
1998 r34 gt-t
248rwkw
HKS GT-RS turbo
pod filter
FMIC
Apexi Power FC
forged internals
cat back exhaust cannon style
fuel pressure reg
walbro fuel pump
stock injectors (to be changed to 600cc with new turbo)
stock AFM (to be changed with new turbo)
Just wondering i have sold my GT-RS turbo to make more power was thinking of putting on a garret GT3582 to make the 300rwkw+ mark but would i have a real unresponsive lag monster???? what turbs would people recommend for more power but still responsive?
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
