ATR43G3 .82 with high pressure actuator:
800cc injectors
Nistune ECU
Z32 AFM
600x300x75mm FMIC
3inch turbo back exhaust
3inch intake pipe with pod.
CP pistons
Stock engine head
Stock cams
Stock cam gears
Stock exhaust manifold
Stock inlet manifold
Stock fuel rail
Stock engine block, Con rod & Crank.
This is a controlled run based on BP 98 Fuel, No boost controller, No wastegate controller.
Video of above run is up for people whom's interested to watch:
R33 GTST turbo PU high flowed .82 with high pressure actuator:
800cc injectors
Nistune ECU
Z32 AFM
600x300x75mm FMIC
CP pistons
Pu high flow .82
Stock engine head
Stock cams
Stock cam gears
Stock fuel rail
Video of 3 dyno runs:
Final result:
rebuilt RB25 with forged pistons etc
GTR Injectors
Z32 AFM
Nistune + RB20 Computer
VCT running via eboost-street between 1500 and 4500rpm
Running 18psi on a GCG highflowed RB20 turbo
Full 3" straight through exhaust with one muffler, split pulse dump pipe.
Makes 236kw @ 6300 - 7200rpm on 18psi, drops down to 15psi by redline due to the tiny exhaust housing.
Makes 210kw on 12psi at similar rpm.
rev limit at 7500rpm
think the dyno is fairly low reading as the car is an absolute animal to drive, turbo has basically standard response and absolute zero lag, can make about 6psi by 2500rpm, full boost by about 3-3.5k
1993 R33 series 1 GTS-T
Hypergear ATR43G2 highflow turbo (0.82ex 0.60A/R)
Nismo 740cc injectors
Bosch 044 mounted in tank
3" Just Jap dump/front pipe, unknown rattly cat (probs gutted/fked compliance or something), 3.5" catback
Splitfire coilpacks
ViPEC v44 ECU
Large FMIC
3" metal intake, pod filter, fibreglass cold air box w/ heat shielding inside
284rwkw @ 15psi on PULP98
R32 with Rb25 with all standard internals
Gt35/40 with 63 rear
6 boost manifold
tiall 44mm external gate
sard 850cc injectors
split fire coils
2 1/2 " exhaust
race cat
haltech e11 v2
blitz dual solenoid boost controller
bosch 044
running 23 psi made 398 rwhp for a year
turned timing down still on 23 psi making 387rwhp
pump fuel
Edited by jordy86
ATR43G3 twiked version in .82 with high pressure actuator set at 17psi:
R33 RB25det fully stock
800cc injectors
Nistune ECU
Z32 AFM
600x300x75mm FMIC
98 Fuel.
R34 GT-T
RB25DET Neo
Hypergear ATR43G3 hi flow, standard nissan compressor housing with 0.82 exhaust housing.
3" Turbo back exhaust
Custom 3" to 2.5" intake with Apexi Pod Filter
Trust Turnflow Intercooler
Z32 AFM
Nismo Fuel Pump
Deatschworks 800cc injectors
Nistune
BP Ultimate 98
279.5rwkw @ 15.8psi, couldnt get the turbo to hold 17psi to redline. Should be some more top end power once we sort that out.
HUGE thanks to Trent from Status Tuning and Tao from Hypergear!! The amount of time they both spent helping sort out issues such as twisting intake pipe, changing spark plug gaps, trying different actuator settings is much appreciated.
R33 Gts-t Series 2
unopened rb25det
Garrett GT3076R .82
RB25DET
Hybrid Front Mount Intercooler
3A Racing Pod Filter
Nismo 740cc Injectors
Z32 Air Flow Meter
Custom 3 inch metal intake pipe
Garrett 3 inch Dump pipe
Modified 3inch JJR front pipe
Fujistubo 3 inch Catback
Greddy Cam gears
Bosch 040 Fuel Pump
Ported Exhaust manifold
Blitz Dual SBC spec r
All controlled by an Apexi Power FC
Making 281.1rwkw with 19psi dropping to 18psi
Next is E85 ;)
  • 3 weeks later...
Nothing new here
But i picked up one of those GCG 3071r copies s/h not realizing at the time how much different it would be
Feels good but wishing i had the genuine garrett now, of course, hindsight is a wonderful bitch
Full boost comes on a bit later than I'd hoped, around 3800rpm. But its done now... :P
@18psi, tapers down to 16psi
Edited by Arthur T3
Duel ceramic Ball bearing OP6 R34 Neo turbo high flow
R33 RB25det fully stock head and forged bottom.
800cc injectors
Nistune ECU
Z32 AFM
600x300x75mm FMIC
98 Fuel.
Video footage
Duel ceramic Ball bearing ATR43G3 Prototype 2
800cc injectors
Nistune ECU
Z32 AFM
600x300x75mm FMIC
4inch intake pipe with pod.
98 Fuel.
Power curve of last two runs. (car's developed a valve bounce issue)
Boost
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
