  • Replies 81
Ive been getting wildly drunk like an 18yr old the past few weeks:(
I plan on this training paying me back two fold when the night before the next track day i get all the GTR boys so bent out of shape they cant find 2nd gear, with me hopefully being a little less worse for wear:)
Forget room for smokers and non smokers, i think we need to get a room for the drinkers nad non drinkers so those sane ones amongst us can get some sleep:)
just blame the tyres mate it works for me :)
krzysiu, get out there and kick some gtr arse for the gtst club :D
Hehe yeah,, probably can make it. Lol the only gt-r's i could beat would be stock ones lol ;) I know this will sound stupid but where is the Winton fun day?? :S
I would be right up for it, sounds pretty good. Never been on a track doing any racelining, the relax enviroment sounds like a good opertunity to get out there a introduce my self to circuit. however it not really set up for raceling, but im keen an would be good to meet some of you guys
I was thinking that we should arrange an earlyish cruize up to Wang. Have a SE Megamart meet then a Meet at Hume hwy (Ford or Maccas) Maybe about 12-1pm Cruize up and settle in at our accomdation, get some grub early and hit the can. That way we can be in bed by 12 and getting up at 7ish wont be as big a problem.
Roy can stay up all night dribbling crap to the passengers that come along.
Scott (Chrisman) and Chris (Me - Scotsman) want to start looking at prices for accomodation people so please register your interest here for booking numbers:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=56574
Treo: There are 30 year old std cars there, so yours will have NO problem. The most important thing to remember is; Drive within the limits of your car and yourself, and also have a GREAT weekend.
Check your fluids, overfill them a little, get some top self brake fluid ($40-$50) so you still have brakes by the end of the day. And bring the required safety gear; Helmet, Long sleeve t-shirt, jeans, runners, etc.
Hope to see ya there :)
Alan
Remove black, remove sunroof, and increase the year range 93-97 from your criteria, then you might be able to get a manual gts-t just in time.
Otherwise, good luck finding one with the combination exactly like you want.
hi guys! my first post!
im in for sure!
that is if i get a car in time im in for sure!
guys im looking for a 94-5 black manual gtst with a sunroof
help me out
cheers
ipg
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
